Thought I'd say hi
Replied by Whiz on topic Thought I'd say hi
Posted 11 years 10 months ago #100283
what, you cant take pics because it failed the MOT? :p
by Whiz
Replied by Nobrainer on topic Thought I'd say hi
Posted 11 years 10 months ago #100284
No. More because its cold outside!
Posted 11 years 10 months ago #100285
There you go. A nice warm photo :-)
Last Edit:11 years 10 months ago by Nobrainer
Last edit: 11 years 10 months ago by David Aiketgate.
Posted 11 years 10 months ago #100287
www.eurocarparts.com/ecp/c/MG_MGF_1.8_1996/p/car-parts/suspension-and-steering/suspension/suspension-arm-and-suspension-joints/?617750010&1&92516457ae04583a6796207422984aecd3e8af17&000019
Is this the right ball joint?
Replied by David Aiketgate on topic Thought I'd say hi
Posted 11 years 10 months ago #100288
On the handbrake:- The usual problem is the mechanism on the rear callipers has semi or totally seized. Take the callipers off and get the lever moving and returning properly. There's a how to You probably won't need to dismantle the calliper; just get some lubrication into the pivot and get the lever moving.
Posted 11 years 10 months ago #100289
Nobrainer wrote: www.eurocarparts.com/ecp/c/MG_MGF_1.8_1996/p/car-parts/suspension-and-steering/suspension/suspension-arm-and-suspension-joints/?617750010&1&92516457ae04583a6796207422984aecd3e8af17&000019
:nonod:
This one.
2 X MGF / MGTF FRONT TRACK ROD ENDS / TIE ROD ENDS GSJ827
Completed
Last Edit:11 years 10 months ago by David Aiketgate
Posted 11 years 10 months ago #100290
looks nice from afar...
if attaching pics, if you press 'INSERT' next to it, then the picture will go into your post rather than as a separate thumbnail :)
by Whiz
Posted 11 years 10 months ago #100291
I pressed insert, sir....
Posted 11 years 10 months ago #100297
Well done david, well done.
Nobrainer, if you order thos TRE, can you see if you can get two sets for a discount? haha
by Whiz
Posted 11 years 10 months ago #100393
Whiz wrote: Well done david, well done.
Well I would but I reckon any discount would be wiped out by the extra postage to you.
Posted 11 years 9 months ago #100783
Quick question. Just bought some MS wheel hub adaptors as I have lots of wheels floating around from other mgs. Will I need spigot rings and if so any idea what size? Wheels I have are BRM cosmos, ZS straights and some compomotive MO5.
Posted 11 years 9 months ago #101019
Took the hard to off today (in the rain :-( ) as I needed to do a bit of a service and put up the soft top. This meant geting the tape out!
Last Edit:11 years 9 months ago by Nobrainer
Last edit: 11 years 9 months ago by Nobrainer. Reason: Inserting!
Time to create page: 1.707 seconds
