Demisting.
Replied by minimax on topic Demisting
Posted 3 years 7 months ago #200617
Airportable. you are right. It isn't unduly pricey, either.
by minimax
Replied by David Aiketgate on topic Demisting
Posted 3 years 7 months ago #200620
https://www.heatedwindscreen.com/products/mgf-heated-windscreen
Replied by talkingcars on topic Demisting.
Posted 3 years 7 months ago #200715
..........I really ought to wire the mirrors through the hrw as well. Every electron counts on a cold morning!
The mirror heaters are live all the time the ignition is on.
Posted 3 years 7 months ago #200716
I know it seems counterintuitive but using the air conditioning is a very effective way to clear condensation mist from the windscreen as it’s dry air
As I keep saying, it is air CONDITIONING, not air CHILLING.
Posted 3 years 7 months ago #200717
Being used to a heated windscreen,........
Heated screens are available from Ricky Evens Motorsport. I have one in my F and one the garage to go in the F I share with my lad.
Replied by minimax on topic Demisting.
Posted 3 years 7 months ago #200719
Wiring the mirrors through the HRW reduces the starting current draw by two Amps. If you need either then you need both and vice versa. I am aware of the heated windscreen, it has already been discussed in this thread, as has the use of air conditioning. The best solution for me has been to buy a more appropriate car for wintry conditions fitted with all of the above features as standard and much better lights.
Last Edit:3 years 7 months ago by minimax
Last edit: 3 years 7 months ago by minimax.
Replied by Goodwood on topic Demisting.
Posted 3 years 7 months ago #200720
Yes. That makes a lot more sense and is a much easier solution. Save your MG for nicer weather!
Replied by bryan young on topic Demisting.
Posted 3 years 6 months ago #200737
My Mk1 MGF door mirrors heat up whilst the engine is running, there is no switch to turn them on & off, they are permanently connected.
Posted 3 years 6 months ago #200739
Exactly. Ridiculous, isn't it? Running the battery down for nothing when that current could be turning the engine on a cold morning.
by minimax
Time to create page: 0.424 seconds
