Sounds like an air raid siren!
  • Pusb
  • Apprentice MGer
  • Apprentice MGer
Sounds like an air raid siren! was created by Pusb
Posted 3 years 5 months ago #201109
My MGF has started making a very strange sound. I'm hoping someone on here recognises it! Its intermittent, but when its there its very loud. It does change pitch with RPM, but not in a direct correlation (if that makes sense?)Being in gear or out of gear makes no difference, nor does having the clutch engaged or disengaged. Speed makes no difference. Any ideas what it could be? Its louder on the passenger side. I was thinking possibly the fuel pump?
Last Edit:3 years 5 months ago by Pusb
Last edit: 3 years 5 months ago by Pusb.
  • Pusb
  • Apprentice MGer
  • Apprentice MGer
Replied by Pusb on topic Sounds like an air raid siren!
Posted 3 years 5 months ago #201110
The following user(s) said Thank You: Leigh Ping, sworkscooper
Replied by neilpinleeds on topic Sounds like an air raid siren!
Posted 3 years 5 months ago #201111
Auxiliary belt slipping or in contact with something. Cambelt in contact with something. Cambelt tensioner bearing shot. Just suggestions. Is it a VVC?
  • Pusb
  • Apprentice MGer
  • Apprentice MGer
Posted 3 years 5 months ago #201112
Non VVC engine.
Cambelt and auxiliary belts were changed in August
by Pusb
Replied by Airportable on topic Sounds like an air raid siren!
Posted 3 years 5 months ago #201113
Alternator belt slipping?
Replied by David Aiketgate on topic Sounds like an air raid siren!
Posted 3 years 5 months ago #201120
Sounds more like a bearing than a belt.
Complete guess, but alternator bearing? Belt on too tight?
Try putting different loads on the alternator e.g. headlamps on. Does the sound change with load?
Try loosening or taking the alternator belt off.
Replied by deepfat on topic Sounds like an air raid siren!
Posted 2 years 10 months ago #203965
Is it possibly your passenger screaming in fear!
by deepfat
Replied by Notanumber on topic Sounds like an air raid siren!
Posted 2 years 10 months ago #203968
Are you sure it is more on the passenger than the driver's side as my first thought is the cambelt cover rubbing against the pulleys. The plastic cover is far from rigid hence some have retro fitted an extra bracket or sometimes a spacer to keep it away from the cam pullleys
Replied by R40MGF on topic Sounds like an air raid siren!
Posted 2 years 10 months ago #203974
I would go with a over tensioned aux belt resulting in bearing failure.
Time to create page: 0.590 seconds
