Advice on replacing 135 thermostat please.
  • TA22GT
Replied by TA22GT on topic Advice on replacing 135 thermostat please.
Posted 2 days 11 hours ago #224515
Bit of a pain isn't it?
Water leaks with these cars is very scary for obvious reasons and they hold so little water to start with.
I did have some oat in the water so it was pink on the floor.
It's drained and waiting for the parts.
Good luck with yours.
What do you think of my thoughts earlier on not cold starting?
I don't have a P Scan..yet..but will eventually.
Replied by Airportable on topic Advice on replacing 135 thermostat please.
Posted 2 days 10 hours ago #224518
I would only comment on problems within my terms of experience.
You will have looked at all the parts which I would have checked & if after verifying those items & found little to be concerned about, it’s time for an OBD reader.
Those with a PScan would have already have had it on the car, hence my opening comment, however your car is a tf as far as I recall, you might be able to glean some information of a cheap reader.
I had an ELM ??? remote reader on my departed tf, this reported to my phone, I didn’t use it for serious fault finding, I didn’t have any faults but it did log some interest stuff.
It wasn’t expensive at all & it could be the window through which you might view your mystery.
It’ll be in one of the drawers & you could gladly have it, providing I could find it.
  • TA22GT
Posted 2 days 9 hours ago #224519
I do have a cheap OBD reader that works on the Yaris but it won't connect to theTF. Ironically I have never needed it on that car.
I will buy a P Scan when funds allow but right now I have to rely on old brain power and there's not much of that left.
My main concern is having it watertight and it soon will be.
Hopefully the temp sensor and Iavc cure the poor start.
Will soon know!
Replied by Red110 on topic Advice on replacing 135 thermostat please.
Posted 2 days 8 hours ago #224521
I had to change the Coolant temperature sender in the TF (and the 90, immediately after), but the symptoms were rougher than yours, I believe.
It could well be the stepper motor, is that what you mention?
I am sure you’ll work it out soon 😊👍🏽
by Red110
  • TA22GT
Posted 2 days 8 hours ago #224522
Thank you Pedro I appreciate that.
I think it is the stepper motor not responding to the input signals. It doesn't seem to open to let air through to a cold closed throttle and yet hunts when the engine is warm.
I have ordered the ECT sensor and the stepper motor. I was going to try the stepper motor first but seen as it is drained of water I might as well just fit the sensor. In fact that is what I will do then fill it and see if that works. If not I will replace the stepper motor.
When I remove the motor and turn the ignition on I expected to see the plunger move to "a starting position" but it doesn't move at all.
Maybe it is stuck in the middle!
Posted 2 days 7 hours ago #224523
Pretty common problem in Defenders (mine does not have one anymore), I am sure TFs are about the same 😊
by Red110
  • TA22GT
Posted 1 day 3 hours ago #224541
I ordered parts on Sunday from 2 different places and both arrived today. Result!
Replaced the thermostat to water rail hose, replaced the ECT sensor whilst it was drained and refilled.
I had my old IAVC ( stepper motor) off and when I plugged the connector in and turned the ignition on nothing happened. It was closed.
I then plugged in the new one and it moved to allow air to pass.
I knew then that was the fault and after fitting it and a test run all was back to normal.
I'll leave it a couple of days to make sure it"s watertight and then add Oat antifreeze.
Fingers crossed.
The following user(s) said Thank You: R40MGF, Red110
Replied by generous_dad on topic Advice on replacing 135 thermostat please.
Posted 3 hours 56 minutes ago #224563
TA22GT, apologies. Trouble with logging in.
We are in Edinburgh in September but that is still 2 hours from you.
I see you have some joy so long may it last.
  • TA22GT
Posted 3 hours 30 minutes ago #224564
Hi Gen Dad...thanks.
I know I am going to be much further North in September at my sons hotel but not sure of dates.
It is actually pulling harder than it has ever done.
Although it has been a pain I have learned so much about my car.
I'm now very familiar with what is lurking in the engine bay and I have become very good at getting the engine cover off and back on again!
Time to create page: 0.656 seconds
