Advice on replacing 135 thermostat please.
I have not removed the inlet manifold but I think I may have to.
Drained the system.
Removed the expansion tank and oil dipstick pipe.
Removed the half inch hose on the side of the thermostat.
Removed the bolt holding the thermostat to the block.
Removed the two bolts on the water rail..what a pig.
I can feel the thermostat move but in the short time I gave it, dinner called, I could not pull it out from the block. Not having a new one to hand I am not sure where and if I can lever it.
Is there a knack?
Do I have to remove the hose from the left hand side of the water rail?
To get a real tug do I have to remove the inlet manifold and risk damage to the gasket?
To remove the manifold I take it the rocker cover needs to come off to allow it to come out of the engine apperture and the risk of a rocker gasket.
Golly Gosh..I'm not enjoying this at all..I work on the theory that the least you take off the less you break.
Thanks in advance.
Replied by Delbourt on topic Advice on replacing 135 thermostat please.
Posted 2 weeks 1 day ago #224180“Tip based on my experience when removing the coolant rail from the thermostat housing.
Most advice that I have come across, recommends 'removing the 2 bolts attaching the coolant rail to the engine block, then removing the single bolt that attaches the thermostat housing to the engine block'.
I tried this and managed to removing the thermostat housing from the water pump but couldn't remove the coolant rail.
I recommend leaving the housing bolt in, to provide an anchor to remove the coolant rail, then remove the housing bolt (because you can grip the housing with your hands and wiggle it free from the water pump).
Also a mirror under the coolant rail saves a lot of hassle locating the coolant rail mounting bolts)”
Replied by TA22GT on topic Advice on replacing 135 thermostat please.
Posted 2 weeks 1 day ago #224182I removed the two bolts from the rail but never checked to see if the bracket had broke adhesion from the block.
I didn't spend too much time on it but tomorrow pm it will get my full attention.
Many thanks.
Away
Replied by Airportable on topic Advice on replacing 135 thermostat please.
Posted 2 weeks 1 day ago #224183Following the approved technique can be an anathema to one used to the cavalier methodology, however the book is written to guide the mechanic to work as efficiently (cheaply) as possible.
One eye on the job & the other on the bill/till.
Posted 2 weeks 1 day ago #224185No excuses but I only gave it a couple of tugs and it only moved slightly.
I am pretty certain the bracket hasn't broken free from the block as per Wild Rover and kindly related by @Delbourt..
Tommorow pm I will find out.
I may even have a thermostat by then.
Away
Posted 2 weeks 1 day ago #224187M
Replied by Notanumber on topic Advice on replacing 135 thermostat please.
Posted 2 weeks 23 hours ago #224191You must replace the thermostat housing's large O rings. Order them now if you havent already got them as it is well nigh impossible to refit this properly with the old ones.
The 2 bits of information above should save you at least an hour of frustration
Posted 2 weeks 23 hours ago #224192I am realising firstly the rail bracket is not free of the block. I can tell the stat is original and those bolts have never been undone.
I did think it would be easier if the left hand hose was disconnected and you just confirmed it.
I assumed it came with a new O ring. I have a jar full of O rings from various boilers so fingers crossed!
Posted 2 weeks 23 hours ago #224193Please Log in or Create an account to join the conversation.
Replied by Cobber on topic Advice on replacing 135 thermostat please.
Posted 2 weeks 21 hours ago #224194Do you have a lot of experience with old boilers?I have a jar full of O rings from various boilers
Posted 2 weeks 21 hours ago #224195Much more than I do with K series engines!
Posted 2 weeks 20 hours ago #224196"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
