Brake Upgrade kits
Brake Upgrade kits was created by David Aiketgate
Posted 14 years 1 week ago #18780
Many people find the standard brakes adequate at best, and often the first choice for an upgrade is to swap the fronts to the AP setup.
This does improve the overall braking, however it does shift the brake balance forward, as the rear setup is not altered. It also means that those with 15" and even some 16" wheels have the added expense of buying a new set of road wheels!
An alternative to the usual AP front calliper/304mm rotor setup is the upgrade kit that I will be trialling very soon.
This includes 280 mm discs all round and better callipers front and rear. This means that not only do the brakes remain well balanced, this upgrade will fit beneath all 15 and 16" MGF/TF wheels!
Watch this space! I will add more information to this thread as it becomes available.
Last Edit:14 years 1 week ago by David Aiketgate
Last edit: 14 years 1 week ago by David Aiketgate.
Replied by David Aiketgate on topic Re: Brake Upgrade kits
Posted 14 years 1 week ago #18782
For those who already have the AP setup, the rear upgrade will be available separately.
I believe there will also be a 300mm rotor/ calliper upgrade to replace the AP fronts as well.
Replied by Ozzy on topic Re: Brake Upgrade kits
Posted 14 years 1 week ago #18784
/tentative...
by Ozzy
Posted 14 years 1 week ago #18786
Ozzy wrote: /tentative...
That's a bit cryptic for me, mate.:blink:
Replied by David Aiketgate on topic Re: Brake upgrade
Posted 14 years 1 week ago #18836
Some more information on these upgrades that I will be trialling soon.
A Northern Motor Sport Company will provide 285mm disc/rotors with lightweight racing callipers/pads and SS braided brake hoses.
The Basic package for the front will be a set of SS braided hoses, two plain 285mm discs(separate bell and rotor type), a pair of 4 pot racing callipers with Greenstuff pads.All bolts, fitments supplied.
The Basic package for the rear will be a set of SS braided hoses, two plain 285mm discs(separate bell and rotor type), a pair of 2+2 pot racing callipers with Greenstuff pads.All bolts, handbrake cable and fitments supplied. The rear callipers operate two pistons for braking, with an additional pair of pistons operating separate pads for the handbrake.
These packages will fit under all standard MGF/TF wheels(inc. 15")
These are bespoke 95.25mm PCD rotors/discs. They are not re-drilled to the correct PCD.
The calliper are full sized lightweight racing callipers. They are not blocked out to fit the 285mm rotors.
it will be possible to buy front or rear upgrade separately.
This basic setup can be upgraded with 6 pot front callipers; Grooved or Grooved/Drilled rotors; and upgraded pads.
There will be an option for those wanting to upgrade their AP setup. This will include 300mm rotors, 6 pot callipers and SS braided hoses.
Posted 14 years 1 week ago #18855
The total(front and rear) Basic setup will cost £599.
The Basic front setup will cost £349.
The Basic rear setup will be £250.
To upgrade to front 6 pot callipers will be £75 extra. The advantage of 6 pots over 4 is less pedal force required for the same braking force. Better, more even, pad wear and better heat dispersion.
It will be possible to have front and rear upgrades to 300mm rotors.
Replied by andy1970h on topic Re: Brake Upgrade kits
Posted 14 years 1 week ago #18862
This looks really interesting. I've go the standard fit APs on my TF160 so getting larger rear disks to give a better balance would be a good option.
I'm assuming those are kit prices and fitting would be extra - I'm not sure I trust myself to mess around with the brakes.
Posted 14 years 1 week ago #18863
The company have made a wonderful offer. Free fitting for T Bar members! if you travel to them, obviously!
Replied by rough luck on topic Re: Brake Upgrade kits
Posted 14 years 1 week ago #18864
Woow typical ..lol
I just upgrade my rears then a better alternative comes along
A couple of questions though
If I have AP's on the front and replace the rears with 300mm's and six pot calipers would the rear bias be too much
Also if I have AP's on the front would the new front 6 pot calipers fit my existing discs
If you can see were I'm coming from, how to I slowly change over to these brakes as they wear out
cheers
Jon
PS this does seem a bargin if you already have AP's, change over an bang the AP's on ebay
Posted 14 years 1 week ago #18865
I'll quiz the font of all my knowledge and get back to you!
Posted 14 years 1 week ago #18867
david aiketgate wrote: The company have made a wonderful offer. Free fitting for T Bar members! if you travel to them, obviously!
Sounds like I'll be making a trip oop north next year then.
Posted 14 years 1 week ago #18868
You could come and do a Border patrol run and combine it with new brakes!:lol:
Time to create page: 0.638 seconds
