radiator fan test.
Dieter wrote:
marlow wrote: Engine bay fan was on but couldn't hear the rad fan,??
Broken cap could be an option.
How about the idea to check the front fan fuse at first ?
What VIN is your MGF. May be it's still the old setup with 15amps only. Prone to fail :rant:
Fan fuse is located inside the bonnet fusebox. Replace it with 20amps in any way.
Good point Dieter! :yesnod:
Disconnected temp sensor,- - No fan .
Checked fuse , - - Blown.
Replaced fuse ,- - No fan.
So Im going under next t see if the fan is kaput.
I've ordered a pressure cap as well , Says it has a brass valve not plastic ,?
I.ll let you know what I find.
that sounds like an OEM cap :thumbsup:marlow wrote: ......I've ordered a pressure cap as well , Says it has a brass valve not plastic ,?......
Pete Vickerstaff
MG F/TF Central
- your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
The fan works , with a feed directly across it , So thats ok .
There is No voltage on the fan plug with the sensor disconnected and the ignition on.
There is voltage at the fuse.
Sorry to keep asking questions , but any other ideas???
Pete Vickerstaff
MG F/TF Central
Check fuse 6 in the fuse box under the steering wheel that is also for the rad fan. :yesnod:marlow wrote: That's affirmative.
- wire broken on the way to the fan plug. Below the car.marlow wrote: Well now I'm stumped .
- relay broken (less common)
see also on the right here
Good to hear that you've solved the rad fan problem! :yesnod: :thumbsup:marlow wrote: Ok got a result. The engine has to be running , not just ignition on , the fan started as soon as the plug was disconnected, So its just wait for the pressure cap to arrive and see if that cures it.
I'll have to remember about the engine running. :broon:
- a Guest
- Visitor
