low coolant alarm
Replied by ianovic on topic Re: low coolant alarm
Posted 12 years 6 months ago #59384
Softly~Softly wrote: Really Ben, have you got a link I can look at :-?
I just seem to see people raving about them, but never seem to see people saying how it saved their car :whistle:
Thing is sofly sofly. I think everyone agrees that loss of coolant will blow your head gasket and seriously dent your wallet.
Now you could check your coolant level every morning. Who does? In any case its most unlikely that a leak will occur while the car is sitting in the garage. No, its when you are driving along on a journey that any number of faults could cause a leak and when it finally gets low enough the engine overheats, the rest is history.
I have arranged mine with a green coolant level ok indication and red if low.
As soon as I turn on the ignition the green light comes on. Very reassuring.
I installed the alarm about three years ago and the red light has come on once momentarily. The level had dropped a little and a small topup returned the light to stay green.
I love my little green light constantly monitoring the coolant level.
by ianovic
Posted 12 years 6 months ago #59391
Hi Leigh,
Here is the most straightforward circuit which will work perfectly.
Timer is an AH3-3 available on Ebay.
Last Edit:12 years 5 months ago by ianovic
Last edit: 12 years 5 months ago by Leigh Ping. Reason: Pics fixed :)
The following user(s) said Thank You: David Aiketgate, Leigh Ping, bensewell
Replied by bensewell on topic Re: low coolant alarm
Posted 12 years 6 months ago #59395
That's Ace!
Wish I'd have waited a bit before buying the other tackle.
Posted 12 years 6 months ago #59405
Last Edit:12 years 6 months ago by ianovic
Last edit: 12 years 6 months ago by Leigh Ping. Reason: Tidied. Great tip, thanks Ian :)
Replied by Leigh Ping on topic Re: low coolant alarm
Posted 12 years 6 months ago #59424
Superb! :broon:
Posted 12 years 6 months ago #59426
Leigh Ping wrote: Superb! :broon:
Excellent. Simple and easy....
Shame I went out and got all the other gear but hey i've been waiting to get one installed for a while.
Replied by bryan young on topic Re: low coolant alarm
Posted 12 years 6 months ago #59427
I have just fitted a B&G one on my F, cost £100 and easy to fit, i should have waited too :rant: :rant:
Replied by Forrester on topic Re: low coolant alarm
Posted 12 years 6 months ago #59559
Can somebody explain why you need a delay timer with the float switch?
Also what else would I need. Basic instructions would help as well.
Thanks,
Forrester.
Replied by Rich in Vancouver on topic Re: low coolant alarm
Posted 12 years 6 months ago #59560
Jan, I have the B&G alarm and it saved my engine about a month ago when the head gasket went. The alarm went off before the engine overheated. I will be installing another one in my new VVC this weekend. :broon:
Posted 12 years 6 months ago #59565
Forrester wrote: Can somebody explain why you need a delay timer with the float switch?
Thanks,
Forrester.
The timer is to prevent false alarms eg going round a corner fast or going up a hill instructions are on here but I'll be doing one in next month so watch this space
The following user(s) said Thank You: Forrester
Posted 12 years 6 months ago #59566
Rich wrote: I have the B&G alarm and it saved my engine about a month ago when the head gasket went. The alarm went off before the engine overheated. I will be installing another one in my new VVC this weekend. :broon:
Silly questions Rich, as I know that you probably will anyhow, but could you snap a few pics of your installation when you do it please? Cheers :)
Also what else would I need. Basic instructions would help as well. Thanks, Forrester.
Low Coolant Alarm - Installation guide.
David wrote: I know that Russell will supply and fit these systems. If you don't feel confident, give him a try; MGRover solutions, in the glove box, under recommended. :broon:
Last Edit:12 years 6 months ago by Leigh Ping
Posted 12 years 6 months ago #59587
:oops: Ooops David was asking which way up the float switch should be . Well actually they are both correct.
The float switch can be arranged either up or down depending on the circuit.
The diagram showing the float switch on its own is what I have used for my setup. That is with a simple home made electronic timer which I will post.
The float switch position shown together with the delay relay is correct . However my diagram is incorrect.
I would like to put before the court that I rushed this off for a fellow MGF owner who oddly enough reported everything worked perfectly??
I have attached the corrected diagram. A standard LED could be used to dispense with the green ok light if only red was required..
Does anyone know how to remove the incorrect diagram?
Last edit: 12 years 6 months ago by David Aiketgate.
Time to create page: 0.536 seconds
