Getting under the car
Getting under the car was created by Laz1957
Posted 13 years 4 months ago #26363
I don't have any equipment to raise my car.
Is this a good option?
5 piece lifting Kit
Last Edit:13 years 4 months ago by Laz1957
Replied by petevick on topic Re: Geting under the car
Posted 13 years 4 months ago #26365
that would do just fine
Pete Vickerstaff
The following user(s) said Thank You: Laz1957
Replied by Laz1957 on topic Re: Geting under the car
Posted 13 years 4 months ago #26366
Thanks for the advice ;)
Now can someone tell me the way to use this all safely please.
by Laz1957
Replied by Rich in Vancouver on topic Re: Geting under the car
Posted 13 years 4 months ago #26367
That looks OK but I would go for a higher lift jack if at all possible. You shouldn't have to use blocks of wood etc on your jack to get the car to a reasonable height (That gets into your safety question!) Only use the jacking loops under the car don't jack under the sills. There are two loops on the rear subframe and one at the front. (All at the car centerline)
Never work under the car with just a jack supporting it. Place two jackstands under solid points on the subframe, remove the jack and give the car a bit of a wiggle to make sure it is stable before getting underneath. If only jacking one end wheel chocks
should be used. A pair of safety glasses will help keep debris out of your eyes.
It really all common sense.
Oh yeah...A creeper will make working under the car much more pleasant . :)
The following user(s) said Thank You: David Aiketgate, bryan young, Laz1957
Posted 13 years 4 months ago #26369
Thanks - I'll let you know how I get on - or is that under? :lol:
by Laz1957
Replied by Dieter on topic Aw: Geting under the car
Posted 13 years 4 months ago #26380
> halfords jack
> Lifting range 14 - 38cm (approx.)
That's poor min.height for an MGF. Would recommend to get a similar hydraulic jack 2t as low profile jack.
The are a little bit more expensive but you will like it.
http://www.northerntool.com/shop/tools/product_200326626_200326626
(US site, but available here aswell)
Edit: found it
- Lifting range = 80 to 330mm
http://cgi.ebay.co.uk/German-Unitec-Low-Profile-2-Ton-Hydrualic-Car-Jack-/270686635823
Dieter K.
MGF Rep. MGCC DE
[IMG
Last Edit:13 years 4 months ago by Dieter
Last edit: 13 years 4 months ago by Dieter.
Replied by David Aiketgate on topic Re: Aw: Geting under the car
Posted 13 years 4 months ago #26396
Dieter wrote: > halfords jack
Edit: found it
Yeah, I was just going to suggest getting a low profile jack, as it can be difficult to get a standard one on the front jacking point because of the low bumper/splitter.
Replied by Rich in Vancouver on topic Re: Getting under the car
Posted 13 years 4 months ago #26410
Good point. I can only just fit my jack under the jacking points. Sometimes if the car has been sitting a while I have to give it a bit of a lift to get the last couple of cm clearance. If I install lowering pins I will have problems! :ohmy:
I have been thinking of getting a set of "Race Ramps" I don't know if they are available in the UK but consist of moulded ramps with the ramp portion removable to make it easier to get under. Pretty cool things!
Race Ramps
Last Edit:13 years 4 months ago by Rich in Vancouver
Last edit: 13 years 4 months ago by Rich in Vancouver.
Replied by bryan young on topic Re: Getting under the car
Posted 13 years 4 months ago #26411
That is a nice peice of kit :thumbsup: :thumbsup:
Replied by talkingcars on topic Re: Getting under the car
Posted 13 years 4 months ago #26413
I tend to use the car jack to lift the car slightly to get my trolly jack underneath or park in the road with 2 wheels just on the edge of the pavement which gives an istant 6" lift on 1 side.
Last Edit:13 years 4 months ago by talkingcars
Last edit: 13 years 4 months ago by talkingcars.
Replied by petevick on topic Re: Getting under the car
Posted 13 years 4 months ago #26414
drive up onto a couple of pieces of 2" (or 50mm) timber
Pete Vickerstaff
Replied by Laz1957 on topic Re: Getting under the car
Posted 13 years 4 months ago #26433
OK, after much doubt, I have the car on axle stands :woohoo:
I have loosened the 2 bolts on the hanging hook and the bolt on the backbox strap in preparation for the new exhaust. The bolts on the cat won't budge but I have some Plusgas on the way ;)
2 of the bolts are easy to access but is there any trick to getting at the furthest one?
Also I won't have the Plusgas until tomorrw - is it OK to leave the car on axle stands for that length of time?
by Laz1957
Time to create page: 0.536 seconds
