Getting under the car
- bryan young
Laz1957 wrote: OK, after much doubt, I have the car on axle stands :woohoo:
I have loosened the 2 bolts on the hanging hook and the bolt on the backbox strap in preparation for the new exhaust. The bolts on the cat won't budge but I have some Plusgas on the way
2 of the bolts are easy to access but is there any trick to getting at the furthest one?
Also I won't have the Plusgas until tomorrw - is it OK to leave the car on axle stands for that length of time?
Should be ok to leave on stands, providing they are firm on the subframe and on solid ground, if worried pop the wheels back on with a couple of nuts. my F has been on stands for over a year now and my MGB is also up on stands to take the load off the tyres and stop flat spots.
You may have to resort to cutting the cat nuts off and getting a "cat saver nuts kit" ~ you may need to leave the plus gas 24 to 48 hours to release the bond, apply at regular intervals. you can also try tightening the nut a bit first as this sometimes will break the rust bond. another trick is to put some heat on them, pencil flame on a blowtorch and heat one side then try undoing them. if this does not work then apply more plusgas while they are warm. please keep us informed on progress :omg:
Good luck with the bolts :yesnod:
You'll be OK to leave the car on stands, as long as no one is going to run into it. :whistle:
I would try a dremel cutting disc on the third bolt. :broon:
I have removed the nearside rear wheel to make things easier to get at and remembered the reversing lights sensor, so I have the engine inspection panel off as well now :lol:
I scraped one of my rear calipers with a wrench and the gold paint flaked revealing red underneath - which is the colour I want them :lol:
So I now have 4 jobs on the go.
Fit new exhaust - 1 bolt left and waiting for gaskets and saver nuts (tomorrow hopefully)
Check/replace reversing light sensor
Remove gold paint from rear calipers
and most important of all fix the gear change problem :lol:
- Rich in Vancouver
However, the 3 bolts that connect from the cat are really coroded and won't budge (yet)
Also, we cut the wires to the reverse switch and bypassed the switch - both reverse lights came on so I thought I'd order this:
Can now see the gear linkage better but that will have to wait until tomorrow
Note all jobs done today thanks to the help of my son
Laz1957 wrote: 3 nuts all removed and exhaust is off :woohoo:
Note all jobs done today thanks to the help of my son Yaaay, run free, Rohan!
