Its never that simple, it just can't be one thing
- rough luck
- Site Sponsor
- Jon
Replied by rough luck on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29007or bleed it rite through the disc before bleeding at the back
Replied by xad3888 on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29020rough luck wrote: If its an early F your clutch may have a damper disc near the clutch master cylinder they can be a real pain to bleed properly, easiest way is get a Guderson power bleeder about £20 an fits the clutch filler
What's a Guderson? I use a Gunson one man bleeding kit that works well on clutch and brake systems.
The Gunson kit has a tank for new fluid which is pushed under air pressure (from the spare tyre) into the master cylinder and pipe work when the bleed nipple is slackened and why it's such a handy device for DIY one man operation.
John's right about the cars fitted with a clutch damper being a PITA - despite using the Gunson.
This method worked for me:
- Charge the Gunson with new fluid and connect it to the master cylinder and spare tyre.
- Slacken the pipe connector at the damper unit that comes from the clutch master - until fluid comes out, then retigten.
- Repeat with the pipe connector going to the clutch slave.
- Now you've no air in the clutch damper.
- Go on to bleed the slave cylinder.
Tip:
Be aware that clutch fluid strips paint - wiggle some some plastic sheet (from a milk carton) under the clutch damper to divert lost fluid onto absorbent rags.
HTH Jeff
By the way, the clutch damper physically gets in the way if you are removing the wiper motor and mechanism complete. There are two 8mm bolts holding it to a mounting plate. One is in a slot. Slacken both and the damper will be able to twist a few mm in that slot - just enough to let the wiper assembly come free. No need to slacken or disconnect any hydraulic pipe work if you are careful.
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29037When Gunson's say to keep the air pressure below 20psi pay attention!
A couple of years ago I was bleeding the brakes on my TR7 and I didn't
have a spare tire with air in it to pressurise the system. Of course the front
wheel was right there, and not wanting to take the wheel off and up to the local garage to refill it later
I didn't bother lowering the tire pressure to the recommended 10-20PSI.
Big Mistake! I hooked up the hose and heard a "POP" as the master cylinder
tank blew apart. A cloud of vaporised brake fluid rose into the air then settled onto the car.
Luckily there was a hose handy and I was able to wash down the car before the paint was
destroyed but it was a scare!
So.....Mind the pressure! :broon:
BTW: Has anyone been able to modify a cap to use the Gunson with the MGF master cylinder?
- a Guest
- Visitor
Replied by a Guest on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29052Please Log in or Create an account to join the conversation.
- Rich in Vancouver
Posted 13 years 1 month ago #29055As long as you keep the pressure where it belongs with the Gunson
there are no problems...at least there haven't been for me.
You don't have to hear the wife complain about getting cramps in her pumping leg either! :lol:
Replied by mowog73 on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29070[size=10pt]Mark[/size]
95 MGF
Replied by David Aiketgate on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29073David
- IPEX-731BA5DD06
- Apprentice MGer
Replied by IPEX-731BA5DD06 on topic Re: Its never that simple, it just can't be one thing
Posted 13 years 1 month ago #29188Here's a photo of the old dust seal and the replacement fitted.
The Needle nose Pliers are in the broken part of the seal, you can see the small break in the seal, right where it fits into the groove in the push rod, enough to let in the air. :whistle:
I've yet to fit this, been struck down with a slight bought of stomach flu or mild Gastroenteritis combined with my volunteering, travel, and weather, I just don't have time or inclination to fit. That and I'm lazy, slow, and just so tired lately.
BUT, fit this back, bleed air out of system, spray the brakes with the lithium spray, and work the Gear selection lever (probably 1st thing to do) it should be all up and running again. :broon:
Assuming it so, next project will be fitting a glass rear screen, my 2nd plastic screen has gained a 2nd tear in the plastic, and tape won't hold it now. I assume cost will only be..ONLY... a couple hundred AUD $'s , YEAH why not. :omg:
Seen a video on how to fit,http://www.the-t-bar.com/en/forum/54-how-tos/21787-fitting-glass-screen-panel
, seems easy enough, even I could do it in 30 minutes, double his time. :woohoo:
- Rich in Vancouver
Posted 13 years 1 month ago #29189If I was to do another one it would take me half that. It's a relief to do a simple job on an MGF for once!
Posted 13 years 1 month ago #29198David
Posted 13 years 1 month ago #29199[size=10pt]Mark[/size]
95 MGF
- IPEX-731BA5DD06
- Apprentice MGer
Posted 13 years 1 month ago #29771I think I have an idea of what the problem is, 2 fold.
1) ME..Just lazy and not confident.
2) I think the clutch needs to be removed and renewed. :sick:
Question on the release arm, how far should it move with the slave cylinder pushing on it, mine moves about 2 Cm's in an arc, or about 10 Degrees on Arc. Is this far enough???
I've had it working previously, but no power to drive, it sounds like the clutch, from what I've read, here, at MG forums, etc.
Bah, all things wear out, even I do... :oops:
