MG T-Bar Quiz
- cjmillsnun
Mal7921 wrote: Ok, folks, after a sleep I now have a question...
What is this?
Ahh the Metro Pizza Van.
It's an engineering mule to prove the mid engined K series layout for the MGF.
http://www.mgf.ultimatemg.com/group1/mgf_spy_pix/mgf_spy_index.htm
- cjmillsnun
Anyway...
*thinks*
Name the engine and the cars it was fitted to.
- bryan young
- bryan young
PQD44 wrote: Sorry for the delay gentlemen, yes Mal was quite right. :woohoo:
Before you can remove the timing belt you need to remove the lower crank pulley..
To do this you need to lock the flywheel, hence the reason for removing the starter motor.
:welcome: to the MG Quiz Mal. Tradition has it (at least it used to be this way) that you now set a new question. It can be anything MG related, just use the site search facility to check if the question you want to ask has been asked before.
If you're stuck, just let me know and I'll set a new question.
Russell uses a battery operated impact wrench :woohoo: and dont need to lock flywheel or gearbox (in gear) :slapme:
cjmillsnun wrote: Name the engine and the cars it was fitted to.
Chris, is this derived from the G Series (Galileo) Common rail diesel engine, developed from the L Series engine, that was earmarked by MG Rover for, amongst others, to go in to the MG ZR in 2005/6?
The engine is currently made in India and used in the Indian ICML Rhino and the General Motors Tavera.
Or is it to do with something beginning with W, as Bryan said?
The MG link, simple as that.
Good luck hunting.
Further information can be found here http://books.google.co.uk/books?id=csZRy1YY0_EC&pg=PA71&lpg=PA71&dq=ye+olde+bell+hurley+mg&source=bl&ots=mr5Bil4orn&sig=aFeyg2PlBHjNF4nrZB8jrVZNocg&hl=en&sa=X&ei=fabVUNm8IKSR0QW-noGgAw&sqi=2&ved=0CGkQ6AEwBA#v=onepage&q=ye%20olde%20bell%20hurley%20mg&f=false
Time for a question with a more a cheerful answer I think, over to you Alan. :frosty:
