Bogey - Progress Thread
well done Ben!
All that work has paid off!! Any advisories?
by Whiz
:drive: just mini nick on cat bend they can weld it for a tenner so I'll get it sorted next week
Good luck at last :pop:
by bensewell
well done ben, glad to see all is well now you can get in it and enjoy it..
by jac114
Todays early morning jobs were
Swapped clock n oil dials around
Coupled heated rear screen up and button
Coolant alarm wired up and tested
Near gear knob alloy bit
New gear knob
Then was going to faff with the dials on the petrol / temp but thought I best get a move.on to work
Getting up early and getting jobs done is working out spot on only downside I'm up at half 5 but tinkering then starts at 6 sleep is over rated
New gear knob
by bensewell
- richandpaula
Good mornings work that mate,
Swapping clock & oil much of a faff?
by richandpaula
Simple job once the console is out its only a few screws
by paulsmgf
The following user(s) said Thank You: richandpaula
- richandpaula
Cheers Paul,
Getting the console out much of a faff?
by richandpaula
Nope its easy just pull in the middle then wedge a few implements around the edges and it gradually pops out, then undo all the button wires (pinch and pull). Then it all comes out.
by bensewell
i swapped my temp and clock over while the top vents were out, you can just reach down.
top of console levers out an inch or two, swapped bulbs at the same time.
Last Edit:11 years 8 months ago
by really?
Last edit: 11 years 8 months ago by really?.
- sherwood0_8
Ben were did u get that gear knob from ? that looks nice
by sherwood0_8
Off a ford Puma. Cost £6.00 on eBay
by bensewell
Time to create page: 0.629 seconds
