- John and Sue
Replied by John and Sue on topic Wocha bin doin on your MG this week then?
Posted 10 years 5 months ago #144047The correct name foe a Senior Moment is a CRAFT incident.
Can't Remember A Fuffing Thing. yesnod:
Replied by PQD44 on topic Wocha bin doin on your MG this week then?
Posted 10 years 5 months ago #144050bacchus wrote: ...
On the subject of oil changes don't you hate it when you find the copper washer that is supposed to be on the sump plug sitting next to your tool box after you have refilled the oil and are packing up ......... :rant:
I'm only forty seven and I'm already having senior moments, what hope do I have.
Craig
Craig, you're 47 and started having senior moments :dry:
I'd say you're doing very well, mine started quite a few years earlier.
Replied by bacchus on topic Wocha bin doin on your MG this week then?
Posted 10 years 5 months ago #144056my craft incidents have been happening for a little while now, late last year I forgot to pick up my son from school until one of the other parents rang me and asked where I was. Fortunately I was only 15 minutes late and Jamie ended up with a new Lego kit courtesy of my overwhelming feelings of guilt.....lol
Craig
Posted 10 years 5 months ago #144835Since its last tracking adjustment the steering wheel has been a few degrees off centre. Not a major problem, but you see it every time you sit in the car.
Removing the steering wheel and moving it one spine merely resulted in the steering wheel being a similar degree out in the other direction. :bang:
So I jacked up the front of the car and removed the front wheels. I loosened the steering track rod lock nuts and turned the offside rod 1 complete turn out and the nearside 1 turn in. Tightened up the lock nuts, put the wheels back on, torqued up the wheel nuts and went for a test drive. :woowoo:
I now have a straight steering wheel. Until the next lazy tracking adjuster type person. :rant:
- John and Sue
Posted 10 years 5 months ago #144837Been meaning to do the track rod trick for weeks now: probably thus weekend. :broon:
Posted 10 years 5 months ago #144840David
Posted 10 years 5 months ago #144841David Aiketgate wrote: I now have a straight steering wheel. Until the next lazy tracking adjuster type person. :rant:
I've clearly got too much time on my hands because I've been watching your little rant icon for the last few minutes :doh:
It's actually quite good as it goes through quite a large range of movements when you look closely.
Sad bugger that I am :coat:
Still busy day tomorrow fitting big brake discs. Wish me luck!
Robin
Posted 10 years 5 months ago #144846Use the through bolt trick to get the old discs off. :broon:
Removing old discs
Posted 10 years 5 months ago #144850I used the bolt method on the rear discs - worked an absolute treat :broon:
Hopefully, all will be ok. I've got it planned and all the tools ready and waiting. That's half the battle I always think.
I need to do the n/s lower ball joint as well and am still debating whether or not to do it at the same time as I'll have a lot of what's needed to be dismantled done. It may be a bridge too far though so will see how the offside goes.
Robin
Replied by Beth557 on topic Wocha bin doin on your MG this week then?
Posted 10 years 5 months ago #144856This evening is devoted to getting a low coolant alarm, hopefully one which doesn't require me to drill a hole in the expansion tank as this idea scares the bejesus out of me.
If anything else goes wrong on my car it's going on eBay.
Replied by mogatrons on topic Wocha bin doin on your MG this week then?
Posted 10 years 5 months ago #144862... Here's hoping your luck turns soon. :yesnod:
