Replied by BruceTF135 on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 6 months ago #190259
Thanks for the tips on extracting the remains of those pesky disc retaining screws, guys. The helicoil kits are sufficiently cheap that it has to be worth giving it a go :-)
Replied by Denmark on topic Wocha bin doin on your MG this week then?
Posted 5 years 6 months ago #190325
Replaced cambelt, waterpump and man tensioner. No problems and not as expected from various posts and forums.:woohoo:
Last Edit:5 years 6 months ago by Denmark
Last edit: 5 years 6 months ago by David Aiketgate. Reason: Inserted photos
Posted 5 years 6 months ago #190326
Not as difficult as expected i ment
by Denmark
Posted 5 years 6 months ago #190340
Taxed it..
Posted 5 years 6 months ago #190347
Same as me Mr B . Then this happened .
Posted 5 years 6 months ago #190348
To explain the pictures in my last post . It shows the broken bolt hole on the drivers door handle . Which inexplicably decided to break when I opened the drivers door for the first time since last year ! MGF N TF bits supplied a replacement the next day but it needs painting so can't get that done until possibly next week. Ho hum !
Replied by mowog73 on topic Wocha bin doin on your MG this week then?
Posted 5 years 6 months ago #190349
I've had that happen to a couple door handles. I've had success gluing the bolt hole back together with epoxy.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 5 years 6 months ago #190350
Hmm , I did consider epoxy but , I could just picture my better half's cutting comments if it failed whilst in the middle of our French roadtrip later this year . ' Well if you hadn't been so tight ' sort of comment springs to mind and it's peace of mind plus peace if you get my drift ! :bat:
John
Posted 5 years 6 months ago #190353
First day back on the road today and after my pitstop at home checking around and a wash n wax..I went out for a chippy tea and stopped at rudyard...everything working as it should apart from me.
Replied by VX54NEW on topic Wocha bin doin on your MG this week then?
Posted 5 years 6 months ago #190354
I have just repaired my driver's door handle as I had the screw hole break up a few mo nths ago.:woohoo:
I drilled out what was left of the lug(could not glue it as bits were missing) and gorilla glued a length of M6 rod in the new hole and used a small nut which cleared the lock movement.
After struggling with my sausage fingers to replace the spring clip for the lock barrel,I discovered the easy way to fit.:bang:
Place the spring in its grove on the handle and use a bit of pressure from a prybar or similar
using the inside of the door to push against and the lock barrel just clips in.:clap:
Last Edit:5 years 6 months ago by VX54NEW
Last edit: 5 years 6 months ago by VX54NEW. Reason: Error
The following user(s) said Thank You: David Aiketgate, cairnsys
Replied by Gerry.laing on topic Wocha bin doin on your MG this week then?
Posted 5 years 6 months ago #190362
Changing plugs, leads and coil packs because of a misfire,John was right fault on cylinder 4 plug lead
Slightly hamperd by hail and rain. 🙄☔
Posted 5 years 6 months ago #190365
Glad you've sorted it Gerry . I managed to get my s/h drivers door handle painted and back on. Tested the fob /locking and the EKA, all seems to be okay . Saying that will be the kiss of death knowing my luck . :doh:
John
Time to create page: 1.027 seconds
