- Kiwi2001MGF
- Apprentice MGer
Replied by Kiwi2001MGF on topic Wocha bin doin on your MG this week then?
Posted 2 years 4 months ago #199478I've even found a local company with the correct fluid, I live in New Zealand so don't have easy access to as many suppliers as in the UK.
I'll update once I've built it if it works.
- Kiwi2001MGF
- Apprentice MGer
Posted 2 years 3 months ago #199591Ill replace the airfilter while its all open and we will see if the problem has gone.
Replied by Oh MG on topic Re:Wocha bin doin on your MG this week then?
Posted 2 years 3 months ago #199592Kiwi2001MGF wrote: As my car has dropped a little I started investigating hydragas pump up equipment which led me to AliExpress (again) so I have on order a pump and high pressure no loss Schrader valve.
Nice, I did mine recently, it was low on the left, took surprisingly little fluid to get it back up to match the other side! Makes a big difference.. best of luck!
- Kiwi2001MGF
- Apprentice MGer
Replied by Kiwi2001MGF on topic Re:Wocha bin doin on your MG this week then?
Posted 2 years 3 months ago #199593Please Log in or Create an account to join the conversation.
Posted 2 years 3 months ago #199594Apart from that I STILL have the squeaky front left.. and I’ve removed and checked / greased the shock, arm, joints and everything else.. I’m 100% sure it’s a creaky sphere, I pulled the rubber on the insert and filled it with WD but it still makes a racket.. next stop.. maybe a new sphere, or just turn the radio up.. more news as it breaks..
Posted 2 years 3 months ago #199595Kiwi2001MGF wrote: I bought 4L of fluid as it was all I could get. I think I will be able to go into business pumping up Hydralastic suspension as I will never use all of that on my car!
I’m not 100% sure how much they hold but I’m pretty sure that’s a lifetime supply :lol:
Posted 2 years 3 months ago #199597in an effort to fix an intermittant miss under load.
I used to have trouble with an intermittent miss..... eventually she buggered off with the milkman! :bust: :coat:
- Kiwi2001MGF
- Apprentice MGer
Posted 2 years 3 months ago #199608A successful morning, after finding somwhere that had the correct fittings to connect the schrader valve to the hose on my pump, we pumped up the suspension.Kiwi2001MGF wrote: As my car has dropped a little I started investigating hydragas pump up equipment which led me to AliExpress (again) so I have on order a pump and high pressure no loss Schrader valve.
I fitted an icecream container in the pump for ease of cleanup and flushed it with diluted antifreeze afterwards.
Massive improvement to the ride, the car had dropped by about an inch.
Sent from my SGP611 using Tapatalk
- Kiwi2001MGF
- Apprentice MGer
Posted 2 years 3 months ago #199719Last night we fitted new plugs and coils (coils from Aliexpress) in an effort to fix an intermittant miss under load.
Huge improvement in drivability and low rev torque, I am very surprised.
- neilpinleeds
Replied by neilpinleeds on topic Wocha bin doin on your MG this week then?
Posted 2 years 3 months ago #199798Please Log in or Create an account to join the conversation.
Posted 2 years 3 months ago #199811Oh MG wrote: FINALLY got round to swapping out the rotten underfloor coolant pipes for stainless ones, sourced from Sam’s Autos.. I have to say, grovelling around under the car undoing 6000 bolts which hold the skid tray on was awful, but rewarding, old pipes off, gave the inside of the rubber a good scotchbrite to get rid of any red death clinging on, a wipe of hylomar around the ends of the new pipes and it all fitted perfectly! Cooling system bled in the three points and the heater is hot and engine cool :lol: although while the cover is off (for the thousandth time this year) I’m going to bleed the clutch and lube the clutch arm and cylinder, it’s an oft missed point but can cause real headaches on these! God bless ‘working from home’ :lol:
<a href="https://ibb.co/c3W8DhK">
Stupid image hosting… :lol: there!
Posted 2 years 3 months ago #199818Sent from my iPhone using Tapatalk
