Replied by Pharg55 on topic Wocha bin doin on your MG this week then?
Posted 1 year 4 months ago #203107Please Log in or Create an account to join the conversation.
Posted 1 year 4 months ago #203110Please Log in or Create an account to join the conversation.
- billcoleman
- Journeyman MGer
Replied by billcoleman on topic Wocha bin doin on your MG this week then?
Posted 1 year 4 months ago #203111Pulled out all the heater ducts and evaporatort to clean them out and fix all the air leaks.
Adjusted the vent outlets so they close off correctly.
And just finishing off by moving an underseat sub into a different place that doesn't vibrate the arse off the passenger. I think I can pull the speaker out of the box and make a new box that fits in the back of the centre console/behind the armrest.
Maybe I'll fit a new radio with DAB.
Replied by TaffD on topic Wocha bin doin on your MG this week then?
Posted 1 year 4 months ago #203115Please Log in or Create an account to join the conversation.
Posted 1 year 4 months ago #203126I was surprised to read it too.
https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-3-1
States that there must be 2 stop lights fitted, any over and above this can be disabled.
Posted 1 year 4 months ago #203128Please Log in or Create an account to join the conversation.
Replied by MAXTHEDOG on topic Wocha bin doin on your MG this week then?
Posted 1 year 3 months ago #203585Mechanical -
Finally got the low coolant alarm installed. Worked first time!
Replaced the plastic radiator bleed screw with Mike Saturs one.
Installed a brake servo strengthened from MG Mania.
Bling - seat belt escutcheons and seat belt tidies both from MG Mania.
While doing the alarm I noticed the areas that would benefit from Dinitrol or Bilt Hamber-ing. Seen some rear bushes that are looking a bit ahem worse for wear but there’s no knocking yet.
Cheers,
Michael.
Posted 1 year 3 months ago #203589This evening I’ll be refitting the high level brake light, which should have been done before I went away. Behind the door amongst the pile of junk mail we’re several packages for development jobs. One of which is a push switch for supplementary boot lights, it’s dark at the back of the garage in winter & extra few lumens won’t go amiss after our shopping trips.
I drilled the pilot hole earlier, finish the job off now.
Posted 1 year 3 months ago #203614Before I went away I harmonised the wiring with the box mounting & was happy with the results. Due to my advancing years & my being away from the White Heat of buggering about for a couple of weeks I forgot I'd changed the wires about & managed to drill through the supply cables, blew a fuse & rendard several devices inactive. Yes I am a tit & you'll all know what this afternoons job will be.
Posted 1 year 3 months ago #203615There are worse things to be than a tit……a silicone tit for instance
Posted 1 year 3 months ago #203616Please Log in or Create an account to join the conversation.
Posted 1 year 3 months ago #203692I made a slight adjustment to the soft top on the 115 which makes the back edge fit slightly lower against the bodywork. Then I tidied up a scruffy scrape on the drivers side wheel. Im hoping to take a few photos of the 115 over the next couple of evenings ready to advertise it.
