Replied by MAXTHEDOG on topic Wocha bin doin on your MG this week then?
Posted 9 months 3 weeks ago #203771Driving around it seems to have less rattling and creaks. But that might well be my imagination. 🤷♂️
Doing the floor pans I think will make a big difference.
Washing it earlier I noticed the instrument binnacle is cracked as they do towards the centre console. Anyone done a repair without sourcing another?
Michael.
Posted 9 months 3 weeks ago #203781That sound a win to me.
The mistake with the binnacle was noticing it in the first place, you will notice it every time you go near the car, you’ll have to attend to it or you’ll get no peace.
Posted 9 months 3 weeks ago #203790Please Log in or Create an account to join the conversation.
Posted 9 months 3 weeks ago #203796Structurally it was fine but there was a shinny line where the cyno’ had been drawn in & that irritated probably more than the crack.
A few weeks ago I commented that when I first got my f the plastic bits had little value & my pet scrappy was happy for me to help myself to whatever I wanted, whether off the f’s & tf’s.
A conversation I had about a binnacle, unbroken at the front, went just like this; “how much for this lot” I asked waving a binnacle & other bits “the tabs are broken on that” pointing to the binnacle, “you can have that, the rest give me a fiver.
And that dear friend is how I ended up with a flawless binnacle although I did reenforce the areas prone to cracking.
Posted 9 months 3 weeks ago #203797According to Roger Parker’s F/TF Restoration Manual that’s the common place.
At the moment it doesn’t bother me as I only see it when I’m washing it - I creep up on it from behind to get in!!
There seems to be a few on yon EBay for what I consider a reasonable fee (£25ish). I am after all someone who has forked out in an earlier life for head gaskets and timing chains etc on a Jaguar XK8.
At any rate there’s another pack of sound deadening pads inbound so that’s got priority when it lands, and a passenger door rattle that does irk a LOT.
Regards,
Michael.
Posted 9 months 3 weeks ago #203798What materials do you recommend?
Posted 9 months 3 weeks ago #203799I commented on the lack of mounting clips around where you have your discontinuity ( I’m avoiding any chance of more smutty humour from the man down under). If it were fixed how on earth are you supposed to remove the instrument cluster? If I’d acquired one with clips I think I’d have removed them.
Posted 9 months 3 weeks ago #203800https://www.deadening.co.uk/products/dodo-mat-deadn-hex-20-sheets
Very easy to work with, cuts with scissors.
Cheers,
Michael.
Posted 9 months 3 weeks ago #203803Please Log in or Create an account to join the conversation.
Posted 9 months 3 weeks ago #203806I was surprised to see the heatshield was missing then realised a PO had removed it to reuse the right hand mounting point as an anchor for a bracket to support the side of the cambelt cover.
I wanted to fit a heat shield but thought it could be useful to keep the cambelt cover support as it had clearly been fitted for a reason and though it was a bit Heath Robinson it did the job nicely.
By carefully grinding the edge of the thick steel metal plate it was possible to gain enough clearance so that this could be fitted back on the mounting point once the heatshield was in place. . The long bracket was then able to be rebolted to this.
At some point i will give the bracketry a coat of VHT manifold paint. Also i spotted a cut out area on the back of the cambelt cover so will search for something I can make a solid job of covering that with.
Posted 9 months 3 weeks ago #203831The replacement has a glass rear screen and was easy to fit as it came with the frame. 4 bolts, 2 helpers, 10 minutes.
Its slightly dusty from where it was stored so I'l wash it with the car one evening and give it a quick coat of Febsil as that stuff worked wonders on the 115's hood
Posted 9 months 3 weeks ago #203836Please Log in or Create an account to join the conversation.
