Posted 11 months 2 weeks ago #217638I love the warm sound of valves and the fact there are no PCB's so they can easily be repaired by an amp tech.
I'm sure your son will look after them.
Posted 11 months 2 weeks ago #217640Made to last and made to be repairable
Posted 11 months 2 weeks ago #217641Please Log in or Create an account to join the conversation.
Posted 11 months 2 weeks ago #217643A bucket of components was taken into the workshop & experimented with until the amp stopped blowing up & eventually sounded right. Ken Bran had more idea than most & the Orange amp was designed by Matt Mathesius in Yorkshire.
Posted 11 months 2 weeks ago #217644Its not just the tread, it's sidewall compliance and a bunch of other factors. TFs with 16" wheels are even more sensitive than those with 15"s to the extent that even quite a premium tyre which is still wrong for the car can make it handle unpredictably. Theres a lot on this and the other forum on tyre choice for this reason. Im sorry you have only just seen this after investing in a pair of rear tyres and hope you can find another purpose for them or someone to buy them to recover much of the cost.
Posted 11 months 2 weeks ago #217646I have had both on my car and would be happy with either but I did replace the Toyo's with the Falken 310's if that is any use to you.
Posted 11 months 2 weeks ago #217648thats some good insights as the Falkens are cheaper over here, toyo currently almost double as expensive !If you do change them you won't go wrong with Falkens or Toyo's.
https://www.oponeo.nl/band/falken-ziex-ze310-ecorun-205-50-r15-86-v-mfs#596854951
Posted 11 months 2 weeks ago #217649If they are cheaper go with them.
Just a thought...I fitted 205 50 15 all round but I went too wide on the front. The car lost some of its turn in and agility so I have since fitted 195 50 15 but sticking with factory specs of 185 55 15 might be a good idea to keep that front end crispness.
Btw..the Falkens are much quieter.
Posted 11 months 2 weeks ago #217651If you were to turn a Marshall 100 upside down & squint at the gizzards, you would be hard pressed to tell the difference between makes, unless you were a frequent visitor to their nether regions, Carlsbro were almost identical. Most amps of this vintage & form factor used the same construction system & circuit topography. Orange amps were my favourite to work on; as nice inside as out. At least Linden Laney knew about electronics & could predict the outcome of a modification, Marshall copied Fender & they cribbed the RCA application sheet for the 6L6 & 5885.
You know your stuff AP!
Very knowledgeable. I'm told my Laney is a couple of caps and a resistor away from the Marshall 100w plexi. It sounds glorious.
I know the Matamp/Orange story really well as I used two Matamps for 20 years and visited the factory in Meltham many times. In fact I helped them with the functioning and switching of one of their models to get it extremely versatile.
On their wall they have the face plate of the Series 2000 amp that Peter Green recorded Albatross on. Of course I had to fondle it ☺️
You is very knowing geezer mate!
Posted 11 months 2 weeks ago #217655Fender Hot Rod and Vox AC 30 here, used to have a Marshall JCM 900 too
Just so much better than solid state.
Bit on the heavy side, though 😂
Posted 11 months 2 weeks ago #217656Strangely I have never owned a Vox.
Posted 11 months 2 weeks ago #217663They were never cheap, even as raggy arsed, raced & rallied, grey faced, Fane crescendo loaded dog, might leave you dining on beans on toast for a month.
