SPLICE SJ30
The splice connects togther all purple wiring for clock /radio/diag socket/footwell lamps and the one I am interested in -the rear loadspace (boot) lamp.( from FUSE 3 on a 2003 onwards TF)
I wnat to use the wiring for the boot lamp ( the lamp is a power drain liability in my opinion anyway) to wire up a boot release switch -so would be really handy to brake into the purple wire before it gets to the SJ30 splice and the fuse F3
thnaks
Mike
Mike
- BobPatchett
- Novice MGer
When referring to both circuit & electrical diagrams I have both open on my computer & toggle between the two.
Once you have broken through the electricity panic barrier, locating any item becomes procedural.
I can’t help you directly with resolving your problem as I’m in a church yard somewhere in England, but as you have had the foresight to ask on T-bar, you’re obviously bright enough to work this through, once your neurones are lined up correctly.
Best of luck.
1.0 square mm wire from fuse box - 88.5 cm
0.5 square mm wires from:
- load space lamp - 484.5 cm
- front interior lamp (rear view mirror) - 214.5 cm
- diagnostic socket - 92.5 cm
- radio - 35 cm
- analogue clock - 44.5 cm
- footwell lamp LH side - 44 cm
- footwell lamp RH side - 79 cm
After seeing all these measures I see that radio has the shortes path to the splice point. Second one is LH side footwell light. So I assume that splice point should be on the LH side behined the radio.
These are the “map references” to guide you to that “X” spot.
- judiths handyman
and the history of the original post, I think Mr patch it, (gettit?) is a phisherman
he may prove me wrong of course.
- BruceTF135
Given the birth date on the profile, 01-01-01
Err... your birthdate shows the same!
- BruceTF135
- judiths handyman
Thanks for that.
I have now been able to complete my profile, birthdate and all.
I was pleased to note I could allow members only to access any profile information,
I think I may be getting paranoid,
