alternator for mgtf 2003
alternator for mgtf 2003 was created by graham1
Posted 6 years 4 months ago #187023
it is ok found the fuse, what altinator does this take i know its a lucas but wich one. thanks.
Last Edit:6 years 4 months ago by graham1
Last edit: 6 years 4 months ago by David Aiketgate.
Replied by sworkscooper on topic altinator for mgtf 2003
Posted 6 years 4 months ago #187033
Graham you're making me nervous. Your car seems to be leaping from one crisis to another ! :hgf: Are you sorted with the springs ? ? ? Now the alternator ! ! ! I've been on a 1000 mile trip round France recently without a hitch. Am I just lucky or what ?
John
Replied by graham1 on topic altinator for mgtf 2003
Posted 6 years 4 months ago #187034
your a lucky son of a gun. had my problems, but thats what comes of buying a 15 year old car with no service history, this should be my last job now, (i hope) yes the car looks well now,
by graham1
Replied by Airportable on topic altinator for mgtf 2003
Posted 6 years 4 months ago #187035
Your exploits are enough to make any owner twitchy, you also had the head done recently I seem to recall. Ok the f has a broken gear cable, which at 20yeas old &120k miles on it isn't all that surprising but before that neither car has cost a bean, other than farting around stuff & paint. Let's hope you get it sorted so you can enjoy the rest of summer, I looks better now than the last pictures.
Mike
Last Edit:6 years 4 months ago by Airportable
Last edit: 6 years 4 months ago by Airportable.
Posted 6 years 4 months ago #187037
thanks john just changed the battery and it is running with volts at 12.1 volt, do you think i need a new altinator or should i just get mine reconditioned? thanks yes the tripple gasket and lower oil thinggy was done in march, doese't half shift tho. sorry to hear your having your problems, but isent that the fun of it all.
by graham1
Posted 6 years 4 months ago #187038
sorry mike.
by graham1
Posted 6 years 4 months ago #187044
Hi Graham . I had a similar fault with my alternator. The F and TF have an environment from hell for an alternator due to heat . You have to consider if that alternator is worth the fitting of a regulator which was my problem or to just go for a new or well reconditioned unit . Beware of dubiously low priced recon units , they can be hopeless ! :bang:
John .
Last Edit:6 years 4 months ago by sworkscooper
Last edit: 6 years 4 months ago by sworkscooper. Reason: Missed a bit
Posted 6 years 4 months ago #187045
You should be getting about 14 ish volts when running .
Posted 6 years 4 months ago #187046
thanks john, would go for a regulater but i dont know if i have a lucus or a bosh, i will wait until i get my new car next week and then i can take it off and find out.
by graham1
Posted 6 years 4 months ago #187047
only getting 12.1 will fix after next week still running it tho,not wasteing this sunshine,if all fails will call out the breakdown to bring me home.
by graham1
Posted 6 years 4 months ago #187048
Please don't take this the wrong way but unless you have a really good battery you are looking at a chug chug blaaa roll to the side of the road breakdown with just 12 volts going into the battery . I have a feeling that your car has a square fob so that is a lucas system so, I would say that you have a Lucas alternator . Mine has an oval key fob ( Pektron ) and has a Bosh alternator .
It's my birthday today and I have had a few drinkies so if this is all b....s then I'm leathered !
John
Posted 6 years 4 months ago #187049
thank you and happy birthday :pop:
by graham1
Time to create page: 0.576 seconds
