Change the headlights from English driving (right side) to portuguese
- Fast Eddie
- Novice MGer
Change the headlights from English driving (right side) to portuguese was created by Fast Eddie
Posted 3 years 2 months ago #196788Thanks you for accepting me!
I need some expert advice on how to set the headlights to my country law? (Turn from right drivers position to left drivers position) Do I need to find new optics? Or there is a cheaper options?
Replied by Cobber on topic Change the headlights from English driving (right side) to portuguese
Posted 3 years 2 months ago #196789"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by David Aiketgate on topic Change the headlights from English driving (right side) to portuguese
Posted 3 years 2 months ago #196792David
Posted 3 years 2 months ago #196796The Tf does have a lever on the headlamp to stop the left side kick up on the dipped beam, as a temporary solution, but this would probably not be accepted by your MOT equivalent car testing regime.
Posted 3 years 2 months ago #196797David
Posted 3 years 2 months ago #196798N.B. Disassembling the MGF lamps is much easier than the TF.
As a bonus, here's how you can convert the steering and pedals, :tada:
:omg: :bust: :coat:
Posted 3 years 2 months ago #196805All you need to do is remove bumper then the lights from the car, separate the outer glass lens from the light body, then swap over the inner lens.
Put it all back together.
It'd be a good idea to check your reflectors for cloudiness and scorch marks above the globes, if so then your probably better off sourcing good L/H/D headlight units, though you can get the plastic reflectors remetalised, if you choose do do this be VERY VERY CAREFUL separating the reflectors from the headlight body, turn the adjusting screws out and lubricate the ball-end and socket before pulling the ball-end out of the socket.
Posted 3 years 2 months ago #196806Another genius wanted to lower the car down to the weeds, but found the steering box thwarting is ambitions......... No worries he just mounted the steering box upside-down...... Sorted, but for the fact that now he had to turn right to go left and vice-versa! :nonod: He reckoned he got used to it!
And one of my idiot mates had an old Datsun 180B, he managed to break his right leg and ended up in plaster from his toes all the way up to his nuts, and couldn't operate the accelerator pedal........No worries, he solved the problem by removing the ratchet pawl from the seat runner track and would pull himself in the seat against the steering wheel to accelerate and push to decelerate!
By now you might've gathered when an Aussie says: "no worries".........WORRY!
Replied by Volcano on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204269Also, regarding the topic title, what's that about with English R side to Portuguese?
Posted 1 year 1 month ago #204271"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 1 year 1 month ago #204272Coincidence. They should all be equally clear.On both my 1997 MGF's the headlight beam lens on the off-sides have a slight opacity. Where as both cars, on the near-sides beam lens are crystal clear. Is that a coincidence or is that supposed to be that way? I'm not referring to the reflectors.
Posted 1 year 1 month ago #204276Even the reflector in the back of the light seems dull, as is the backside of the glass. It’s greyed.
I wonder can this be removed and maybe cleaned?
