Change the headlights from English driving (right side) to portuguese
Replied by Airportable on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204277As David had said the f light units are easier to disassemble than the tf & once the two parts are separated you can clean until your heart’s content.
Nothing abrasive or a solvent, a mild soap solution on a cotton bud at the edge would be my first move.
I write this with no first hand experience other than having been witness to a guy ruining a similar unit; having chipped the glass & sent one of the clips into the long grass, he then proceeded to squirt the reflector with Amberclens, subsequently transferring all the reflective material from the substrate onto his cloth.
Be warned.
Replied by Cobber on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204278It’s possible the the seal isn’t the best and some filth is getting in, but I suspect that you’ll find the inner lens is buggered
Replied by David Aiketgate on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204286You can easily dismantle the headlamp and clean the lens. However the reflector would need to be re-silvered. Easier and cheaper to buy a replacement headlamp off a later F where the issue had been addressed.
Posted 1 year 1 month ago #204287M
Replied by deepfat on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204288As I see it you have 3 choices:
Get some good S/H ones which is easier said than done.
Get some new ones from Rimmers at over £200 each (ouch) but to make you feel better my TF ones are over £400 each (ouch, ouch)
Get the reflectors re silvered, some companies offer this service but you will have to do your own due diligence as I've no idea of costs or how good this is or lasts.
Once sorted you could consider changing the bulbs to LED which should solve the heat problem, they are off course illegal but that's only really important on one day and they could easily be changed back for that day.
Posted 1 year 1 month ago #204289My off side headlight is date coded 07/11/02 & made in Belgium, the other is original to the car. Could it be that the O/S light units were not up to scratch & subsequently required replacement. Am I over thinking it or could this be another story to add to the list of oddball MG information.
Replied by Volcano on topic Change the headlights from English driving (right side) to portuguese
Posted 1 year 1 month ago #204290Please Log in or Create an account to join the conversation.
Posted 1 year 1 month ago #204291Please Log in or Create an account to join the conversation.
Posted 1 year 1 month ago #204292Please Log in or Create an account to join the conversation.
Posted 1 year 1 month ago #204293Being a monumentally inquisitive bugger, I made a lame excuse about wanting some screws from the garage & went to look at my headlights.
I have two cars both with dulled offside lights, yours M makes three!
Posted 1 year 1 month ago #204294Please Log in or Create an account to join the conversation.
Posted 1 year 1 month ago #204297Airportable I currently have fitted what appears to be a unique O/S headlight designed and made with only 3 screws in the sidelight cover and nobody knows why, the N/S light is a replacement with the normal 4 screws. The photo shows that the little bit of moulding that sits in the middle of the cover doing nothing on 4 screw lights once was a continuation of the main body moulding.
