Re:How often do you need a cam belt service?
- StuartDavidMurray
- Novice MGer
How often do you need a cam belt service? was created by StuartDavidMurray
Posted 1 year 7 months ago #201595
Recently bought an MG TF (2003 In X Power Grey). 54k on the clock. No obvious overheating issues etc (no white gunk in the oil). The HG / Cam Belt was done in 2013 (@ 41k miles) and the alternator in 2019. Should I be looking at getting the Cam belt redone? Thanks, #newbie
Replied by Steve on topic Re:How often do you need a cam belt service?
Posted 1 year 7 months ago #201596
Its actually well overdue, for safety change it now as a matter of urgency, 5 years I believe is the max timespan regardless of mileage.
by Steve
The following user(s) said Thank You: StuartDavidMurray
Replied by Airportable on topic Re:How often do you need a cam belt service?
Posted 1 year 7 months ago #201597
If you consider the mileage it’s done on the current belt you could be throwing a perfectly good bit of kit away. If you look at the age of the belt & you’re into the car for the long run Steve is spot on. Get it & the associated gubins changed now & you have a reference point for the future.
by Airportable
Replied by David Aiketgate on topic How often do you need a cam belt service?
Posted 1 year 7 months ago #201605
:welcome2:
- StuartDavidMurray
- Novice MGer
Replied by StuartDavidMurray on topic Re:How often do you need a cam belt service?
Posted 1 year 7 months ago #201620
Many thanks, have spoken to a reputable specialist to get this sorted. On another note, once a HG has been done, does it ever need redoing?
Replied by Notanumber on topic Re:How often do you need a cam belt service?
Posted 1 year 7 months ago #201636
It would be good to know what the reputable specialist is quoting for cam belt change. Mgfntfbitz have a kit of the belt, tensioner & water pump for £ 60 at present. The locking tools are commonly available.
by Notanumber
Posted 1 year 7 months ago #201658
There's no telling if the gasket will outlast the car or not, my guess would be not, but you can do certain things to mitigate against failure & the first is: if your car hasn't a low coolant warning, fit one with a degree of urgency!
by Airportable
Time to create page: 0.604 seconds
