poor running where to start ?
Changing the air and filters hasnt made any difference. It idles fine and will chug along at urban speeds ok but sounds like an asmathic tractor as soon as its under load, any gradients etc. My first thought is to check the HT side but I'm used to fault finding on older cars with a single coil and accessible spark plugs. Not sure where to start with the coil packs and buried plugs on this. What's the sequence for checking the state of the TF's ignition please ?
Start at the plugs and work your way back.
Replied by David Aiketgate on topic poor running where to start ?
Posted 1 year 7 months ago #201687Corrosion between the coil and the spring can cause uneven running.
The one thing i do know is how the oil came to be there. The funnel slipped when refilling after the oil and filter change i did last week. At the time I'd thought I'd sucessfully managed to mop it all up with rags and like an idiot didnt think about any finding its way under the cover and depositing itself into the nearest spark plug well ( which #4 is).
Having already ordered new plugs, leads and coil packs il wait til they arrive then change the lot and hopefully it should then run perfectly. Can't wait to start using the TF a bit especially now the weather is improving
Posted 1 year 7 months ago #201702David
