Can anyone tell me if this calliper will fit an MGF 1.8?
Ebay description says it fits a rover 100 or an MGF. I've read in a few places the Rover 100/Metro GTI used the same calliper as the MGF but the Rover 100 has such a long and confusing [at least to me] life I'm sure some of its callipers wont fit my MGF.
Its been over a year since I replaced my MGF's front brakes and the calliper looks right...
Seller says it should work but wasn't very certain/convincing. Can someone with more knowledge please have a look?
Edit: Extra info: Should add that i noticed the front left calliper wasn't returning very easily when i replaced the disks last year. Didnt have time to clean it and have driven about 2000 miles on it since. Recently noticed a continuous, faint metallic scrapping noise while driving that goes silent when braking. Jacked up the wheel and it spins real freely/nice but can hear the metallic scrapping noise as it rotates.
Edit Edit: I've just carefully re-read the title of the item i.e. "SOLID BRAKE DISC ONLY". All MGF's have vented discs so i think i've answered my own question. This isnt gonna fit an MGF 1.8
ROVER METRO 100/ MGF, SOLID BRAKE DISC ONLY L/H FRONT BRAKE CALIPER, LUCAS
Completed
Last Edit:1 year 6 months ago by djkeenan
Last edit: 1 year 6 months ago by djkeenan.
Replied by Airportable on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202076
There's something decidedly odd about it, pass it up & go for one that with definitely fit. It’s too late to go & check one of my spares but this is a critical component so don't chance it. And it’s definitely much too late when the brake pedal goes to the floor & the countryside is approching at a singularly dispiriting rate whilst there's a distinct squeak coming from a rapidly distending sphincter.
Last Edit:1 year 6 months ago by Airportable
Last edit: 1 year 6 months ago by Airportable.
Replied by djkeenan on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202077
I hate asking questions but everyone on this forum is so nice. Thanks for taking the time to respond and its sound advice.
I'm gonna leave this and try and repair/clean my calliper once I get back from my travels (300 miles round trip to the south).
Replied by Notanumber on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202085
Before you replace the caliper I recommend you try this. i have used this to good effect on single and dual pot calipers on a number of cars with good results.
Unbolt the caliper. Get someone to very (very very) slowly and gently push on the brake pedal so the piston extends. Do not overdo this as you dont really want the piston to pop out altogether.
Clean the piston with brake cleaner or similar and a rag. If there are any obvious rough spots caused by corrosion then very very carefully rub them with fine wet and dry paper just to take off any high points and then clean again.
Grip part of the rim of the piston lightly with a mole wrench. I would here recommend you use a rag between the jaws of the mole wrench and the piston's surface to prevent risk of scratching..
Using the mole wrench but also your other hand around the exposed piston carefully now rotate the piston by a quarter of a turn. Remove the mole wrench.
Retract the piston to it's normal position. I have managed to do this with just using a large G clamp on it's own without touching the fluid side but I once broke a G clamp so would suggest you use the safer method :- open the bleed nipple on the caliper slightly and apply steady force to push the piston back into the caliper. Take care of fluid spills, ideally have a jar or tray to catch the fluid. . Once the piston is retracted close the bleed nipple.
Clean the caliper, slide in the brake pads and refit to the carrier and brake disk. Toque the bolts to the recommended torque, Dont over-tighten.
Using your preferred technique bleed the brakes. If you were very careful in the last step you should be able to just get away with bleeding that single caliper but if in doubt bleed the whole system.
Drive the car. There is at least a 95% chance this will have cured your problem.
Last Edit:1 year 6 months ago by Notanumber
Last edit: 1 year 6 months ago by Notanumber. Reason: spelling
Replied by MGB281 on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202094
I have never attempted to repair a brake calliper until last year but have now done two pairs. For £30 on ebay you can buy two seal kits complete with new pistons and £13 for new guide pins. I removed the callipers and using a twisted wire wheel and cup wheel removed all the rust down to bare metal. Next I removed the pistons, if you cannot remove them with pliers or mole grips carefully use an airline. It takes very little pressure to pop them out, if you give them a full 150psi blast they will fly around your garage or across Sainsbury's forecourt (don't ask how I know) . Inspect the bores after cleaning them thoroughly any mild corrosion can be removed with wire wool, clean out the seal grooves and re assemble. Watch a you tube video, it's easier than explaining how to do it but there is a simple way of putting the seal on the piston, then putting the outer part of the seal into the calliper then inserting the piston. Re assemble with new pins remembering to put them back the same way they came out. If you didn't do the rust removal it's less than an hours work for two callipers
by MGB281
Posted 1 year 6 months ago #202095
It’s interesting how attitudes change over time. Not all that long ago there was a reluctance to mess with your brakes, a safety critical item & a certain MOT fail if not balanced & up to scratch; especially discs, such was the mystique. Now with YouTube tutorials & the ease of component supply via eBay, folk seem to get stuck in & the first they know that they didn’t quite get it spot on is when the old lady & her shopping trolley are seen out of the corner of your eye disappearing over the hedge in a cloud of flour, sugar, bun cases & mixed fruit.
My advice is never reuse anything you’ve taken out of the suspect unit unless those parts are metal & discarded any rusty item that doesn’t come clean with a wipe. If a special tool is required either buy it, hire it or reconsider. Clean clean clean. Use only specific lubricants i.e. the stuff in the seal kit, replace bleed nipples & change the pipe union if it’s rusty & chewed up, consider replacing the pipe if that’s rusty. Unless you’re going for exotic fluids stick to the recommended DOT rated fluid & don’t let the thought even poke it’s toe into your mind; “it’s looks clean enough, I’ll reuse it”. Brake fluid is hygroscopic, it could be as much as 20%* water.
If you stick to those basic tenets of calliper rebuilding you’ll be fine
*That figure was plucked out of the air as an illustrative.
Replied by trevtherev on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202103
Think that advice is spot on. Critical items like brakes need to be treated with respect because if they fail at worse, it's a rude awakening on how long it is to stop at worse curtains. I had my front brakes replaced at a repair shop and the apprentice didn't clamp the caliper to the hub tight enough and on the way home it fell off, not a great feeling I can say
Replied by Cobber on topic Can anyone tell me if this calliper will fit an MGF 1.8?
Posted 1 year 6 months ago #202109
Yeah I had a front calliper fall off my old Valiant Charger at about 150 kph! A definite brown trouser moment!
The bolts hadn’t had locative applied to them upon installation by whoever did them for the previous owner.
The amount of crap workmanship I’ve found on cars with full authorised dealer service histories is amazing, just yesterday helping a mate with a cam belt change on his mum’s Holden Astra (badge engineered Opel) we found the coil pack damaged by poor handling ( they’d just shoved it back in and hoped for the best ), a broken radiator drain plug ( glued back together) a broken engine mount (given that this car has only ever been driven by a very careful little old lady, unlikely to be caused by her, but highly likely to be caused by careless jacking up of the engine during a cam belt change)
Until yesterday the only people to ever work on this car were authorised Holden dealers ( getting hard to find now since Holden closed up……. And from what I saw yesterday a bloody good thing too)
Posted 1 year 6 months ago #202119
I couldn't agree more with the above statements, there is nothing magical about rebuilding brake callipers, once you have done one you will realise how simple they are to do. Watch the you tube videos, if you are unsure watch them again. For a few hours work you can derust them, rebuild them and paint them. I used these https://www.toolstation.com/abracs-wire-twist-knot-cup-brush/p17385?&mkwid=s_dc&pcrid=653986639419&pkw=&pmt=&gclid=Cj0KCQjwmN2iBhCrARIsAG_G2i72KAvzOz4BKmr3Wu0vhcJIa1eQQ4bYmWPV3eZIU-m-inxG-Z263ucaArqQEALw_wcB&gclsrc=aw.ds and one of these https://www.toolstation.com/abracs-twist-knot-wheel-brush/p67421
Remove the rust before dismantling, reassemble and paint
It costs £43 for a front pair of rebuild kits which include seals, pistons, new guide pins and lubricants. I bought these "speciality tools",
UK 4PCS CAR TRIM REMOVAL TOOL KIT SET PANEL DOOR PLASTIC PRY DASH INTERIOR CLIP
Completed
One has nice rounded ends for inserting the seals into the groove.
by MGB281
Posted 1 year 6 months ago #202121
If you’re going to bottom out the rear callipers, down to the hand brake mechanism it’s very useful to have the long prong circlip pliers, bordering on an imperative.
Posted 1 year 6 months ago #202125
Some blokes will take any opportunity to show pix of their long prong :omg:
Posted 1 year 6 months ago #202127
Me & bloody pictures again. Thanks Cobber, your comments would be more valid if I'd used a 12" rule as reference. (Wishful thinking & / or bad memory?)
Time to create page: 2.782 seconds
