replacing the starter motor
- sworkscooper
John.
My attempts to remove the cover so as to inspect the belt have floundered as I have yet to find out how to access the 4th and 5th bolt. The simple instruction in the workshop manual to "remove the five bolts" does not give any indication as to how to get access to them all!! I will keep looking for a real "idiot's guide" to doing this - but have to suspect that even if I find one I will have neither the tools nor the confidence to complete this apparently simle task..
Mirror tool
One of the bolts is just about the alternator on the right hand side. The bottom one is accessed from the wheel well, its sort of behind the engine support bracket.
If you would like, I could do a video of the location of the different bolt locations.
[size=10pt]Mark[/size]
95 MGF
Better late than never: herewith photos of the spark plugs that you said, some while ago now, could be useful to see.
Regards,
Phil
I think you find that the timing belt has failed causing serious damage to the cylinder head.
It would appear that the pistons on two cylinders have had interment relations with the valves of those cylinders!
The timing cover will need to be removed to confirm this, and the cylinder head will need to be removed to properly assess the damage but I’m betting the engine is fornicated!
Given where you are and the lack of local knowledge of these engines, your best bet will be to locate and import a good 2nd hand engine…. And before installing I’d replace the timing belt, it’s tensioner and associated parts
I spotted this one, which being a VVC from an F should be a straight replacement. https://www.mgfntfbitz.co.uk/shop/mgf-vvc-55k-engine/
It would be worth an email to Darren there to explain your predicament and ask him to calculate the price of shipping to the US as they will export. It would also be worth asking how much extra he would charge to supply and fit a new timing belt and tensioner for piece of mind- and perhaps the clutch too unless the clutch on your old engine was changed quite recently that is.
You WILL get over this . It is achievable and you will soon be back driving the F
Is there a twenty five year rule which says that certain cars not imported into the states for some original perceived non compliance are now able to be tubbed over & sold.
There was a chap looking around for 25year old f’s a bit back, it could easily be the same chap hoovering up Land Rovers. They sell at one hell of a premium out there so an MG could easily be a great prospect.
Not’aNum’ is correct in his evaluation & recommendations & if I’d dollars in my pocket & had something interesting to spend it on that’s where it would go.
As they become fewer their values will increase, not EType values but handy enough to have & less of a worry if it got bent.
95 MGF
Does anyone out there have experience of using a US-based company to import car bits? I have contacted FreightCenter, Freight Specialist and Freightright so far and will continue to search for possible US-based companies, but any suggestions from past experience would be gratefully receved.
Cheers,
Phil
