Sheer pins for steering column ?
Where about is the pin & what function does it perform, is it a sheer pin, what diameter & length, has it a rivet or screw head?
The front shaft and the shaft that goes down to the motor are joined in a tube. The front shaft is permanently welded in place but the other, which is splined is secured by a nylon sheer pin with blind, flush ends.
I take it that in the case of an accident the pin shears & the column telescopes whilst the air bag deploys.
If that is the case & you want to retain that level of safety, you really do need something approaching the original.
If you can measure the diameter I’ll have a rummage in my plastics box, although most of samples in there are probably too resilient.
I wasn’t implying that the pin was instrumental in deploying the airbag, just that whilst one was shearing the bag might be coming to smack you one in the face.
Replied by Notanumber on topic Sheer pins for steering column ?
Posted 11 months 12 hours ago #2055752003 TF 135 sunstorm
I need a new brain ! I searched for ages for nylon shear pins, assuming these were sold as dedicated parts for a number of similar applications and I just wasnt using the right search criteria. it hadnt crossed my mind to look for lengths of nylon and acrylic rod which is exactly what they are. That will do nicely.
We are all in the same boat, judging by re reading some of my posts I wonder what planet I was on when I wrote it.
I did actually think it might be simpler to tap a thread in the outer tube and put a grub screw in.
Replied by Airportable on topic Sheer pins for steering column ?
Posted 11 months 10 hours ago #205578It’ll also give me the opportunity to clear out scraggy ends, mouse droppings & dead spiders.
If you measure the diameter & what sort of length would suit, I’ll tip my box out & have a root. Obviously no promises, but I’ll stick a bit in a jiffy & shunt it down to you if I’ve anything like.
What a great offer not only can he get the bit he needs…. But with bonus mouse droppings and dead spiders! :lol:
Posted 11 months 7 hours ago #205581Big Bugger or fat sod with long legs won’t do, you would have to use Linnaean binomial nomenclature to ensure the corpse is correct.
Mouse shit is mouse shit & that’s optional.
Posted 10 months 4 weeks ago #2055902003 TF 135 sunstorm
