Falken Ziex ZE310
Falken Ziex ZE310 was created by MikaelD
Posted 10 months 1 week ago #205840
As the new owner of an MGF VVC 1998, I have planned to change tires in the spring. I understand that the Falken Ziex ZE310 is a good choice. For the size 185/55/15 there are only extra load tires, while for the size 205/50/15 it is "normal" tires.
I wonder if it matters if there are extra load tires on the front wheels? Can it be positive from the point of view of road handling?
Yes there were a few questions that I would be grateful if you could help me answer.
by MikaelD
Replied by MGB281 on topic Falken Ziex ZE310
Posted 10 months 6 days ago #205841
I have Falken XL’s on my TF and they are great. For the TF they should be extra load front and rear, I am sure someone else will add to this. Having the wrong mix of tyres can be dreadful.
Last Edit:10 months 6 days ago by MGB281
Last edit: 10 months 6 days ago by MGB281.
The following user(s) said Thank You: MikaelD
Replied by Airportable on topic Falken Ziex ZE310
Posted 10 months 6 days ago #205847
A fine choice of car & an excellent vintage.
Welcome along.
I don’t consider the f to be as finicky as the tf but care still has to be exercised with the choice of tyre. I was always an adherent to Avon tyres until they stopped making our size, I have moved over to Toyo proxy’s with good results. However my esteemed colleague’s recommendation & your initial observations on the Falkens cannot be faulted.
Replied by MikaelD on topic Falken Ziex ZE310
Posted 10 months 6 days ago #205854
Thank you for your answers. Is it the Toyo Proxes TR1 that you have on the car?
by MikaelD
Replied by BruceTF135 on topic Falken Ziex ZE310
Posted 10 months 5 days ago #205855
I checked this as I was worried I might have missed that when I bought new Falken ZE310 Ecoruns for my TF. You are right in saying that in the sizes you want, which I believe are the correct sizes for 15" wheels on a MGF VVC, one size is V XL and the other is V only. On my 16" TF wheels, both sizes are V XL so the issue does not arise.
These tyres are very popular on both the MGF and MG TF, so somebody else must have encountered this. You could also try emailing Falken. Or you could contact Demon Tweeks for advice. They seem to do the best deal on these tyres.
Posted 10 months 5 days ago #205863
I have received this reply from Falken:
Whether a tire has the suffix "XL" in its designation or not does not really matter.
As long as the tire meets the specifications of your vehicle, such as the load index and maximum speed, you can fit any tire you want.
XL tires are designed for higher axle loads, so you are right in assuming that these tires are also more stable.
Unfortunately, I can't tell you whether this is actually noticeable when driving compared to a non-XL tire.
I also think that it makes no difference whether you drive an XL tire on the front axle and not on the rear.
However, we always recommend using the same tire manufacturer and the same tire model on all axles to prevent possible handling problems.
by MikaelD
Posted 10 months 4 days ago #205866
Sorry for not answering, every time I’ve been in the garage I’ve been carting stuff about, finished bits in & parts to be worked on out, plus I’ve a tendency to forget.
Now what was the question?
Replied by g4wam on topic Falken Ziex ZE310
Posted 2 months 3 weeks ago #208651
wonder of you have any idea why i have the following issue with these recommended tyres
MGTF 15" wheels
rear has the Falken Zeis with no issue
front pair have made my glued to the road TF  very light...I have tried reducing the tyre pressures but no change in performance
thanks
mike
by g4wam
Replied by Delbourt on topic Falken Ziex ZE310
Posted 2 months 3 weeks ago #208654
Sometime ago I was interested in a kit car. So leaving out some of the detail the basics are as follows.
The kit supplier recommended a tyre and related their experience.
They had one brand/model and size of tyre fitted. They liked it, they liked it a lot. When those fitted to the demonstrator wore out they purchased direct replacements.
The replacements were nowhere near as satisfactory as those they replaced. The tech gurus from the supplier were summoned.
They took those tyres away and ground half the tread off and had them refilled to the demonstrator.
Performance was restored!
The reason is to be found in the fact that vehicle weights have increased and to match that thevtyre manufacturers changed the compounds that the tyre is made from, and thereby the way the blocks in the tread twist when cornering .
So, it matters which car the particular model of cars the tyres are aimed at.
Pay your money takes your chance.
The following user(s) said Thank You: g4wam
Time to create page: 0.603 seconds
