Steering wheel without airbag bulge ?
It's not for my TF, I'l be leaving the SRS system on that, but for the MGF EPAS column which im transplanting into my MGB project car.
Whilst the MGF stalk switches and plastic cowling blend in fine I'm tempted to find an alternative to a standard MGF /TF wheel that doesnt have the airbag centre section.
Replied by Airportable on topic Steering wheel without airbag bulge ?
Posted 9 months 2 hours ago #206269The Mountney had been hung up in the garage for years, it’s still on the Landie although it’s a bit small for a non power assisted heavyweight.
It seems that what we’re once called sports steering wheels are now “Drifting wheels”.
This modern parlance leaves me all at sea.
Replied by Notanumber on topic Steering wheel without airbag bulge ?
Posted 9 months 42 minutes ago #2062722003 TF 135 sunstorm
Posted 8 months 4 weeks ago #206275A direct acting hydraulic system, similar to a large tractor of an approximate vintage.
My pall owns a hydraulic company & we’ve sat down & worked out a parts list (I have the matching pump of a 200tdi) but I couldn’t work up the enthusiasm at the time.
And so a bright & inspired idea drifted away into the sunset over Blackpool, (I though I might dash the poetic muse on the hard concrete of the prom).
The trams are quite good though.
Replied by MGB281 on topic Steering wheel without airbag bulge ?
Posted 8 months 4 weeks ago #206277Chris, I think that the only option is to buy a hub adapter for a Rover 25/MG ZR. That will enable you to use various aftermarket steering wheels, they are about 60mm thick but a flat steering wheel will then have the rim in the correct position regarding the indicator/wiper stalks. It also has the nib to cancel the indicator’s built in.
Posted 8 months 4 weeks ago #206279Last time we were in Ireland we spent a day at one of the many country shows & I photographed every power assisted system used on agricultural vehicles known to man, in some instances measurements were taken.
I sketched up a system idea whilst there & even made an example of a spool valve & a shuttle valve on our return.
I inadvertently got myself involved in a ploughing competition; I bragged about the Ferguson TED20 I had at the time & the two furrow Newlands plough I’d just bough in Scotland.
They though I was an expert, bunged me on a Fergy 35 & pointed to my patch.
I shall make no more references to this.
Sorry I digressed a bit!
Replied by Cobber on topic Steering wheel without airbag bulge ?
Posted 8 months 4 weeks ago #206280Instead of the assistance being applied to the column, like our cars it is applied to the steering rack itself.
Now I haven’t even begun to think this through yet but I would imagine that it would be strong enough to do it.
I imagine that the biggest problem would be getting it connected to the steering column effectively and getting in to work with the landies suspension travel without it effecting the steering adversely.
It would take careful thought.
Posted 8 months 4 weeks ago #206281For manoeuvring where the input is large the valve opens more, reducing the sweat under the armpits; the usual grimace being transformed into a smug smile
Obviously steering left opens one end of the shuttle giving “up” assistance, turn right & the opposite end gives you the”down“ component.
Operating on the drag link reduces worries about suspension articulation & a shorter cylinder could be used as the throw wouldn’t be as significant.
There has been a significant passage of time between these initial thoughts & now, there is every possibility I could have failed to recollect some salient points, for the most part I think it all hangs together.
Posted 8 months 4 weeks ago #206283That’s essentially the David Brown system, double acting ram bolted to the side of the tractor, the drag link operates the valve built into the end of the ram. Personally I like the orbital unit idea, no mechanical linkage between steering wheel and axle, downside is that there is very little feel.One design I toyed with was a double acting cylinder, one end fixed on the drag link, the other to the chassis. The amount of steering input being proportional to the opening of a shuttle valve, a small amount, allowing a small quality of fluid into one end of the cylinder; thus the greater the input the greater the assistance.
Posted 8 months 4 weeks ago #206286I thank you for bracketing my pseudonym in with David Brown; a man who could think through a gearbox design whilst having his breakfast toast, only to have the design on paper before lunch.
I doubt I, or any of my endeavours will be thought of in the same sentence as Mr Browns other venture, Aston Martin.
Posted 8 months 4 weeks ago #206291Please Log in or Create an account to join the conversation.
Replied by Roverlike on topic Steering wheel without airbag bulge ?
Posted 8 months 4 weeks ago #206292Please Log in or Create an account to join the conversation.
