Removing Door Handle
Trying to remove the drivers door handle but can't work out how to detach the rod from the lock barrel.
Do I need long pliars and bend the top part to get it out?
Thanks in advance
it's been a long while since I've done it, and I don't recall how I did it, other than it was awkward.
if you bend it you'll never get it right again, you'll find it very hard to bend anyway, which is why you'll never get it right.
As with all cars unless there is a clip the rods will have to be manipulated to be undone without bending.
you have to remember that these things are deigned not to be able to fall apart easily but to be easy to assemble on the production line using the right technique.
it will be a matter of undoing components in the right order and manipulating them, so as to undo them. it will be a matter of getting them in the right position to unhook the rod from the component.
I suggest consulting the workshop manual, which is downloadable from this site somewhere. (I'm a bit old fashioned and use he paper version) alas the factory manual was poorly written, so can read a bit like gobblygook but unless someone here remembers how to do it the manual will be your best bet.
- Away
Failing that perseverance, you could still do with super strength finger ends though.
Do you have any tips on getting the wire clip off from around the lock barrel.
Regards,
Rob
Does anyone know how the gold metal plate is suppose to stay connected to the the handle on the left hand side. I found the spring in the door well but it does't really seem to fit in anywhere.
If not I'll open up the passeng trim and see how it is suppose towork.
Thanks,
Rob
- Away
If you look carefully around there you will in all probability find witnesses marks; these should guide you to it’s reinstallation.
I’m away so can’t inspect a sample but I don’t think I’m far away with that.
Thanks
Ok,
I'm almost there. Issue now is the spring (in the miidle of the picture attached) doesn't seem to fit in.
I'm assuming it is suppose to fit in the hole in the rod to the left but the angles aren't quite right for that.
I have looked at photos of new handles and the spring looks correct as in not damaged.
Thought I would post first before bending it with pliars to fit or take off the trim on the passenger side to see how it should be.
I guess there is a chance it got bent when the damage to the handle was done but I don't really like that theory.
Any help appreciated.
Regards,
Rob
