Oil temp gauge
- judiths handyman
- Apprentice MGer
I have read some posts on MGF gauges being inaccurate and fitting in line resistors to compensate, but as mine is a 2005 TF I wondered if the same inaccuracies apply?
At a steady 70mph, (3000) rpm, the coolant temp gauge reads nicely just below the centre of the dial.
The oil temp gauge at that speed reads 120c.
Any thoughts and comments warmly welcomed.
Thanks.
Richard.
They should've fitted an oil pressure gauge instead of cheaping out with a temp gauge.
A standard 2” gauge (52mm) goes straight in, assuming you have a degree of athleticism in your finger ends.
You also need an adapter to take an extra sensor, a doubler.
The OEM temp sensor comes out & goes binwards, to be replaced with the doubler, then the one supplied with the gauge goes into one hole & the sensor for the pressure gauge fits into the other.
The biggest problem is getting under the car to access the unions which are adjacent to the oil filter.
A couple of digital gauges & a double adapter shouldn’t cost more than fifty quid & then you’ll know what the script is & it could save you a dickens of a lot more than that in repair bills.
- neilpinleeds
- Journeyman MGer
- neilpinleeds
- Journeyman MGer
Rover probably went for temperature because it was cheaper with less wiring/plumbing.
- judiths handyman
- Apprentice MGer
I have a better understanding of oil and temperature ratings now.
I have fitted an oil pressure gauge to my Morris Minor, just to keep an eye on the engine condition and on long runs it can indicate when viscosity changes through heat I should pull over for a cooling session.
Having covered over a hundred miles none stop yesterday, mostly motorway speeds and noting the max temp to be 120c I feel confident the engine is doing all the right things for the moment.
I do check oil and coolant water regularly, so I am hopeful of a lot of trouble free miles.
My only regret is I didn't buy a TF earlier.
Even the missus approves.
Thanks again for all the input.
- bryan young
The gauge does react to oil temperature, it just doesn't necessarily give an accurate reading. Some years cars, the gauge was miles away from true.
Fitting resistors into the line can bring the readings near to actual, but as long as you know what your particular gauge reads under normal conditions, then any rise from that should give you pause.
Being somewhat anal, I spent a fair bit of time with an InfraRed gun and a selection of resistors to get my gauge to read near actual temps.
I also swapped out the original gauge and clock for a matching set of pressure and temp gauges. I had to reuse the original oil temp sender and the new temp gauge read the same as the old, so that confirms it is the sender which is wayward.
- judiths handyman
- Apprentice MGer
I am not too concerned now I have all the information at hand. I understand the benefits of an oil pressure gauge, but I am of the "If it ain't broke don't fix it" brigade. The car is low mileage (purportedly now 14,000) with a good service history, the usual suspects, head gasket, water pump, cam belt have been replaced and additionally I had the stainless pipes underfloor fitted, so reliability is hopefully a near given. Confidence comes with mileage.
You’ve an HGV a couple of foot from your rear & a SUV trying to push in in front.
Concentration levels are high & you fail to notice the oil can & then you become the problem instead of being part of the effect of another’s problem.
A small beeper wired across the oil light would warn in these conditions & remind you to bring the revs up instead of just letting them idle, which is when the pressure is at its lowest with a hot engine.
Just a thought.
