Vibrating Instrument binnacle cure
Replied by Airportable on topic Vibrating Instrument binnacle cure
Posted 2 months 4 days ago #207514I have a flexible grabber (expect a comment from Cobber), into which I insert a small magnet, this forms around the curves with no problem. It’s a couple of foot long (wait for it) with a claw on the end, available off eBay & an invaluable addition to a tool kit. Especially if like me you use & drop a lot of stainless nuts & screws in places which are difficult to access
I have also googled/youtubed that topic. The example used something like a bicycle tyre lever. I had a tool like that which came with dash cam supply cable fitting kit.
That together with some ice lollipop sticks did the job.
Totally agree about the disintegration of the foam. The remains of that will have to be cleaned out, and something put in its place.
So far one screw removed and recovered.
Just have to work out a way of putting the binnacle back such that it doesn’t move/rattle.
Airportable wrote: To remove the central vent; a broad paint scraper tucked inter the bottom edge of the moulding & using the surrounding dash as a fulcrum, ease the unit out. Originally the seal was foam rubber but in all probability that will have disintegrated, so little or no resistance should be expected.
A couple of foot long…..now you’re bragging!
Reminds me of the old gag……”It’s a foot long, but I don’t use it as a rule!”
Posted 2 months 3 days ago #207519M
I managed to remove two out of the three failed clips that were still in the dashboard. The third was a child of dubious parentage. I had to grind the tip of the screw off and weaken the clip. Recovering them through the vent was doddle. Re fitting the vent was easy too after renewing some foam around the ductwork.
With the three clips out I bonded in three rivnuts using 2 pack JB weld repair plastic glue. So far so good.
I then cut and shaped three aluminium brackets from 30mm equal angle material and reduced the 90 degrees to something close to requirement.
With those brackets in place and nearly tight I bonded the binnacle to the angle brackets. If the perishing binnacle had not slipped a bit over lunch whilst the glue set everything would have been perfect.
So, after lunch I removed the binnacle (unscrewing) the brackets that were now bonded to the binnacle, and risked everything by trying to cut through the glue to re bond the binnacle in place where it should be.
Unfortunately the perishing thing cracked (told you so I hear you say) but not too seriously so I had to overcome that by just renewing the glue and then re attaching the binnacle using some "P" section elastomer that I had in my spares bucket.
All in all it doesn't look too bad, it has cured the rattle and I would adopt this approach again if I had another spare binnacle.
All being well attached are two images. One shows the screwdriver assemble all stuck together with gaffer tape. Yes it is resting above the arch but that was only for demonstration purposes. It was just possible with the screwdriver between the arch and the top of the instruments.
And here is the other
Replied by Notanumber on topic Vibrating Instrument binnacle cure
Posted 1 month 3 weeks ago #2076272003 TF 135 sunstorm
The overall finish is a lot better than the acoustic accompaniment but the reflection is annoying.
Posted 1 month 2 weeks ago #2076992003 TF 135 sunstorm
Another job for winter!
