Vibrating Instrument binnacle cure
Replied by Airportable on topic Vibrating Instrument binnacle cure
Posted 4 days 2 hours ago #207514I have a flexible grabber (expect a comment from Cobber), into which I insert a small magnet, this forms around the curves with no problem. It’s a couple of foot long (wait for it) with a claw on the end, available off eBay & an invaluable addition to a tool kit. Especially if like me you use & drop a lot of stainless nuts & screws in places which are difficult to access
Replied by Delbourt on topic Vibrating Instrument binnacle cure
Posted 4 days 38 minutes ago #207515I have also googled/youtubed that topic. The example used something like a bicycle tyre lever. I had a tool like that which came with dash cam supply cable fitting kit.
That together with some ice lollipop sticks did the job.
Totally agree about the disintegration of the foam. The remains of that will have to be cleaned out, and something put in its place.
So far one screw removed and recovered.
Just have to work out a way of putting the binnacle back such that it doesn’t move/rattle.
Airportable wrote: To remove the central vent; a broad paint scraper tucked inter the bottom edge of the moulding & using the surrounding dash as a fulcrum, ease the unit out. Originally the seal was foam rubber but in all probability that will have disintegrated, so little or no resistance should be expected.
A couple of foot long…..now you’re bragging!
Reminds me of the old gag……”It’s a foot long, but I don’t use it as a rule!”
Posted 3 days 9 hours ago #207519M
