Underbody reinforcement
Hello!
Has anyone removed or replaced the underbody guard?
In my driveway, until I refurbish it, it rubs constantly and I've discovered a new noise (almost certainly coming from there).
My idea is to replace it with a flat iron.
Has anyone else done this?
Thanks, Google Chrome and his random translator..
For my first attempt I will use 3mm steel. Maybe later with a couple of nerves to increase strength.
Do you mean the original part as fitted to our cars or the modified flatter version that the OP is looking for ?Unleashed wrote: You will find this part on eBay I believe? I think it just bolts off and back on with 22 bolts?
I don't know there's an aftermarket part!
Even the ribs and folds pressed into the part will when in combination with all those bolts will add to the torsional rigidity of the car, they may even contribute to a reduction in NVH (Noise, Vibration & Harshness)
Fully agree with the above. It also occurs to me that if your F is grounding on your garage/drive floor, either the ground-clearance is desperately small, or your drive/garage floor or wherever it is grounding must be VERY uneven.Cobber wrote: The fact that there are so many bolts used to secure the plate tells be it must do something to stiffen the car, otherwise they'd just use a few clips of self tappers.
I used to have problems with grounding at a slope reversal where my drive meets the edge of the "main" road outside our house. Since selling the Kit car and buying the standard, (NOT "Sportspack" 1 or 2) TF135, I have never had any grounding problems, despite the appallingly bad state of Devon roads. Are you confident that the Satur suspension was installed and set-up correctly?
The problem is the entrance, which has a slight inclination (I would say about 5-7°) but when it reaches the plane, it is not progressive AT ALL, it goes from the inclined plane to the straight one without any transition, which is why I have a "hump" that in I will briefly lower to make an entrance with a regular slope.
Until I get another "run around" car we are using the TF to take garden rubbish to the tip and despite it being smaller than my old Fabia estate I can get almost as many bags in the boot! It never bottoms out on the speed bumps that our other car scrapes the under body on, the TF never touches them. It must be a problem to some though because someone else asked the same question about removing the reinforcing panel on another forum a few weeks ago.
