Tambourine when cold
Tambourine when cold was created by generous_dad
Posted 1 month 4 weeks ago #207886
Just done 800 miles in the 05 TF with no trouble.
However, when the car is cold, it sounds like someone is rattling a tambourine close the the offside rear wheel.
The noise is linked to engine speed and disappears when the water temp is up (max. 5 minutes).
My suspicion is water pump. Any other suggestions welcome.
Thank you.
Replied by neilpinleeds on topic Tambourine when cold
Posted 1 month 4 weeks ago #207890
Could also be the alternator? They can squeal when under load. It stops once the current demand has dropped.
  • Away
Replied by Cobber on topic Tambourine when cold
Posted 1 month 4 weeks ago #207891
Check the drive belt, it could be slipping
Replied by Airportable on topic Tambourine when cold
Posted 1 month 4 weeks ago #207892
I new a chap who complained about a humming, an almost tuneful sound above 30MPH.
It became unbearable at speeds over 50 & no one could get to the bottom of the problem to a point where he decided to get rid of the car, a car which until then, he adored.
Then all of a sudden, just as strangely as it started, it stopped.
A short time later he found a crushed harmonica on the drive; some “mates” had double sided sticky taped it to the underside of his car.
The following user(s) said Thank You: judiths handyman
Replied by generous_dad on topic Tambourine when cold
Posted 1 month 4 weeks ago #207903
Appreciate the suggestions.
Oddly, today, almost no rattling. Will keep an eye on it.
If it is under the belt cover, it will be my first foray there.....
AP, definitely not in the woodwind family. I'll check my castanets though, in case I mistakenly taped them to the wheel arch..
  • Away
Posted 1 month 4 weeks ago #207905
I was referring to the poly rib auxiliary drive belt.... the one that drives the alternator
  • Away
Posted 1 month 4 weeks ago #207906
I like that, there is an old harmonica lurking about here somewhere, all I need to do is find that and a victim!
Posted 1 month 1 day ago #208266
As an update, the tinkling continued.
Looking around, the aux belt seems to be the problem (as Cobber mentioned).
It was not slipping but vibrating until warmed up. A squirt of WD40 as a test stopped it immediately.
A new aux belt is on order.
Thanks gents & Cobber.
Replied by AU02TF on topic Tambourine when cold
Posted 4 weeks 6 hours ago #208311
Just replaced my auxiliary belt and found the tensioner pulley bearings were shot. The pulley rattled around something awful!
Might be worth checking that too - the belt will not run true if the pulley isn't running straight.
by AU02TF
Posted 3 weeks 6 days ago #208323
AUTF02, was it the timing belt that you changed and found the tensioner or the alternator belt? I thought there was no tensioner on the alternator belt?
We sprayed the alternator belt with the engine running and that stopped the rattling.
Posted 3 weeks 6 days ago #208325
Mine is a 2002 TF and definitely has a tensioner pulley associated with the alternator (ancillary) belt.
It has air con & don't know if that makes a difference.
by AU02TF
Posted 3 weeks 5 days ago #208334
Ah, aircon. That's the difference. No aircon is a straight loop.
Thanks for letting me know. I would have thought mine had fallen off!
Time to create page: 0.703 seconds
