Dead battery following alarm/electrical oddities
Dead battery following alarm/electrical oddities was created by sludge
Posted 2 days 12 hours ago #208910I'll preface this post by just being clear from the get go that I'm only now really trying to get into the more hands-on part of car ownership. Despite being 35, until now I've always been a straight-to-the-garage kinda guy. However, I purchased a 2005 MG TF in August and now doing the upkeep myself.
That out of the way, to the issue at hand and I apologise for the length of the post, but I like to be concise. Saturday evening, I got in my car at the same time as I always do every Saturday to do a 77 mile drive from my sons house back to mine. I unlocked the car, got in and started her and then proceeded to do the full drive with no stops. When I got home though, that's when the weirdness started. I got my things and closed the driver side door and as I pressed the lock button on the fob, I heard the horn been once and no sign of the usual alarm arming noises - weird, never heard that before. I was tired so left it as it was and continued the evening as planned.
The next day, Sunday, I knew it was time to get working on it. My first instinct was to assume it was the car warning me that a door or similar was open, so I reopened the driver side door and closed it again before checking the passenger door as well. Again, the car beeped on lock. I unlocked it once more and tried all four possibilities, the rear boot, both doors and the front bonnet, all of which closed firmly like they always do.
With the car still beeping once on lock, I assumed the issue was still not resolved and so I started to do some Googling and, as expected, found myself directed here towards a couple of related threads, but they were unfortunately unhelpful.
I decided that maybe it was something power related, so with little effort, I removed the black cable from the battery for a few minutes to let the system drain out before reconnecting it. Upon reconnecting, I started the engine and despite everything being closed, I noticed a new light that had never been illuminated before, the door open warning light. Back to Google and results suggested that one of the latches wasn't latching properly, so I opened everything and using a screwdriver, was able to latch both doors and the rear boot lid, with the interior lights and the boot light all going out, suggesting that the car was satisfied that they were properly closed. I couldn't work out how to 'fool' the front bonnet though, but with it closed properly and normally, I put the key in again and started once more to find that the door open light was still on.
With it getting late and dark, I was getting fed up with the problem and new it was something I needed to look into another day, and living behind a locked gate, I was comfortable leaving the car unlocked for the time-being. I drove to the Tesco Express near me, and there were no issues with the drive or the starting/running of the car. Got home, didn't lock it and that was that.
Fast forward two days later to today, Tuesday, and I was getting something out of the boot when I decided to just have a little look to see if the car was still being silly. I put my key in and turned it, expecting to see the red 'door open' light, but was instead greeted with nothing. No lights, no mechanical sounds, nothing. The battery has as far as I can tell gone completely flat.
As I don't have a battery charger on hand, I got a friend to come over and we used some jump leads to try and get some juice in to hopefully start it. I wasn't expecting it to work out, and those expectations were met. After a short while, still nothing. I've seen a couple of threads on here regarding sudden dead batteries, and followed their guidance on things like battery negative cable corrosion etc, but I think it's fairly obvious that the dead battery is linked to this random door open alarm.
So I can be sure I've listed my checks off, this is what I've done/looked at/checked; Have confirmed that all interior lights and rear boot interior light go off when the respective doors/lid are closed, so it's not that. I know the soft top isn't alarmed/powered in anyway but have unlatched and relatched that anyway for good measure. I have checked all the looms I can see and they all look to be in excellent condition, with nothing visibly damaged or looking like it needs to be replaced. I have checked all the relays under the front bonnet, and despite some oxidisation, nothing has blown. Checked all fuses under the steering column and they all look ok.
I'm at a loss on what could cause this door open thing to suddenly trip, and I am 100% certain that there was no red warning light on the drive home, so this has happened as I've reversed on to my driveway and gotten out of my car.
Replied by Cobber on topic Dead battery following alarm/electrical oddities
Posted 2 days 9 hours ago #208921Having said that, your car probably has the later Pektron system which isn't anywhere near as bad as the earlier Lucas 5AS system is at causing flat batteries.
I don't think the door latching would've been my first port a call, I would suspect the door switches themselves, or the wiring loom that runs up to the boot by the boot hinge, this is a first stop check for a lot strange electrical behavior concerning our cars.
Alarms and immobiliser systems can play up for various strange reasons, when I bought my old Ford Falcon ute, it wasn't a runner and had been sitting for @ 2 1/2 yrs, t he plumber that owned it couldn't start it no matter what he tried, so he offered it up for sale, I went around to have a look and noticed that the interior light in the cab wasn't working, I immediately made him a low offer.... which he accepted out of frustration. I then replaced the dirty interior light fuse and the ute started first turn of the key....leaving, the
plumber had a very sick look on his face.
Now I knew how Fords Smartlock immobiliser system works, it uses the door light switches to tell it if the doors are open and if there is something is outside of any of it's parameters it won't let the engine start! I have since bypassed the Smartlock nonsense as it is a constant cause of woes, and not worth the pain and suffering.... you know when they feel the need to call something smart......it isn't!
The whole concept of an immobiliser that is tripped by something as silly as a dodgy interior light is utterly stupid!
Your problem will be as equally silly.
Replied by sludge on topic Dead battery following alarm/electrical oddities
Posted 1 day 14 hours ago #208946I can give a little update; went out and bought a battery charger. Figured it was a good investment anyway. Removed the battery from the car, hooked the charger up and surprisingly, the charger let me know the battery was already fully charged.
I double checked the connectors, and the booklet to make sure I hadn't got anything mixed up and again confirmed that the battery is fully charged - strange.
That then leaves me with even more confusion.
Yesterday when I was trying things, I noticed that with the key turned to full ignition, I was getting a very faint oil light shining red but nothing else. Today that is no longer the case.
Replied by talkingcars on topic Dead battery following alarm/electrical oddities
Posted 1 day 11 hours ago #208948I think the door open light only refers to the boot, it does on my mk1 MGF.
That means that the system thinks the boot is open so turns on the boot light.
The sensor is part of the boot latch.
It is also possible that you are getting a short through the boot hinge wiring which causes the system to think the boot is open.
The boot light will drain the battery in a couple of days.
As for the battery itself I would check it with a good old fashioned multimeter.
If it was completely flat a regular battery charger will not be able to recharge it properly.
If you connect your car to another using jump leads you should get full ignition lights even if there isn't enough oomph to start the car.
Let us know how you get on.
James
Replied by TA22GT on topic Dead battery following alarm/electrical oddities
Posted 1 day 10 hours ago #208950Bad earths cause so much grief!
Posted 1 day 9 hours ago #208954A simple analog type
One of these will quickly pay for itself in the time saved buggerising about. Once you have one you'll wonder how you ever did without one!
You can always drag your battery around to a retail outlet and get them to do a load test for you.
Replied by Airportable on topic Dead battery following alarm/electrical oddities
Posted 1 day 7 hours ago #208958Like Cobb’s I wouldn’t be without it & again it saved me it’s cost with the first series of tests on some very special batteries.
The boot wiring loom is frequently mentioned as a cause of electrical mysteries, it’s the poltergeist in the boot; all is well & then it’s not & you’re chasing all sorts of faults. Then the insidious little bastard takes a holiday & it’s fine again.
It won’t rest on its laurels on its return.
Grafting some fresh wires in will take a few hours of irritation but save days of infuriation.
Posted 1 day 6 hours ago #208962"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 1 day 4 hours ago #208964Just to touch on a few things that were mentioned/suggested, in regards to door switches and lights etc, I was able to rule those out on the first day, when I still had power. By simply latching them I could see the interior lights go off, as well as the boot light going off so if the battery is genuinely dead (which I don't think it is) then it won't have been because of a light draining the battery.
Similarly, when I first tried to use jump leads from another working car, I still had zero ignition lights. It was as if the key just wasn't doing anything. I'm still optimistic that it's going to be something relatively easy to resolve, but I'm also expecting it to be a problem that plagues this car forever, which would suck as I intend to daily it.
Edit: some talk about earth bolts, this is something I'm wanting to follow further, I just need to find a guide of all the known earth points on the MG TF.
Replied by bluebae on topic Dead battery following alarm/electrical oddities
Posted 1 day 3 hours ago #208965Please Log in or Create an account to join the conversation.
Replied by Roverlike on topic Dead battery following alarm/electrical oddities
Posted 1 day 22 minutes ago #208968Maybe this thread could help you: https://www.the-t-bar.com/forum/roverlike-s-guides/97850-mg-f-tf-earth-points-locations-guideEdit: some talk about earth bolts, this is something I'm wanting to follow further, I just need to find a guide of all the known earth points on the MG TF.
Posted 20 hours 18 minutes ago #208974Please Log in or Create an account to join the conversation.
