fuzzy fuses...
Replied by Ulympos on topic fuzzy fuses...
Posted 1 year 8 months ago #209215
"Houston, we have light again". So it's F12 a 15A fuse. And yes, the fuse was melted down. Oh, the older eyes, less 'divine' and flexible body, in a dark garage, fiddling with a flashlight, prevented me from reading the fuse diagram with symbols and abbreviated text properly. All works well now, including the clock. Someone enlightened me, so case closed.
For your info, it's about a TF from 2002 LHD. Fuses are situated under the steering column.
Last Edit:1 year 8 months ago by Ulympos
Last edit: 1 year 8 months ago by Ulympos.
Replied by Airportable on topic fuzzy fuses...
Posted 1 year 8 months ago #209217
Fuse 12! The wiring diagram shows that circuit on F3, is your car on the pektron electronics or the Lucas? The thumbnail of the car shows a tf, I assumed it would be a pektron car in which case it would be 3, on the Lucas system, as you have found out, it’s 12.
Great stuff.
Replied by TA22GT on topic fuzzy fuses...
Posted 1 year 8 months ago #209218
Great stuff.
How do I tell a Pektron from a Lucas please..2002 TF..thanks.
Replied by David Aiketgate on topic fuzzy fuses...
Posted 1 year 8 months ago #209219
Pektron - round fob
lucas- square fob
Posted 1 year 8 months ago #209220
Pektron - round fob
lucas- square fob
Mine is square...better or worse?? 😁
Posted 1 year 8 months ago #209224
Well noticing my square FOB, I guess Saint Lucas will guide me... ;-)
by Ulympos
Posted 1 year 8 months ago #209226
We’ll that all adds up, as to whether you are better off with the Lucas system is a moot point. There are certain aspects of the Lucas which could profit the Pektron & visa versa.
I am of the opinion that the earlier system is more robust & possibly truer to the modular concept.
I have had both systems & am more relaxed with the Lucas, although this opinion is often derided by those who prefer a greater perceived reliability of other manufacturers.
What these naysayers don’t seem to take into account the shear volume & weight of Lucas manufactured items used globally in the automotive industry & since the industry began.
A “Lucas hot spot”, where the wire has melted is invariably due to the car manufacturer specifications rather than Lucas choosing/ making a bad component.
Accountants looking to save coppers in manufacturer can cost the company tens of thousands of pounds by requiring a brassed steal connector instead of a brass connector which has been tin plated.
Anyway, I’ve done some truly awful things to Lucas systems & have only had the failures I duly deserve.
Damp can adversely affect the Pektron, I pulled a one touch window controller out of a car & it was wet through. After a good drying out it worked & I’ll be fitting it shortly.
The trouble with this bit is, the control module I dried out was made by Pektron. Keep that’s just between the two of us, if Cobber find out he’ll have a piss take field day at my expense.
Replied by generous_dad on topic fuzzy fuses...
Posted 1 year 8 months ago #209227
The fusebox diagram is a photocopy of the Rosetta Stone.
Completely meaningless to me. I resort to the guide on this site.
Not surprised you could not find the fault.
The following user(s) said Thank You: Ulympos
Posted 1 year 8 months ago #209229
Thank you for the info...and my lips are sealed.
What were we talking about?
Replied by Cobber on topic fuzzy fuses...
Posted 1 year 8 months ago #209234
Airportable post=209226 userid=5200We’ll that all adds up, as to whether you are better off with the Lucas system is a moot point. There are certain aspects of the Lucas which could profit the Pektron & visa versa.
The Lucas 5AS alarm and immobiliser system does tend to leave you with a flat battery after a few days activated and the car not being used.
After all Lucas is the Prince of Darness who invented the vehicle immobiliser,  the car would invariably be immobilised at any random time regardless of the owners intentions of using the car.
Other Lucas Inventions were the self dimming headlight and the intermittent windscreen wiper and the short circuit. these features would also function at at random times, regardless of the drivers wishes and usually with a cloud of smoke!
Well you're not meant to piss on your Pektron electrical components.....or any other brand for that matter. Were some of the awful things you did to the Lucas components involve pissing on them?
Posted 1 year 8 months ago #209235
Im unaware of any problems having been created by my pissing on any wiring jobs, although uric acid would certainly create a more conducive current path. The window controller did smell a bit off, however in an attempt to eradicate the insect population which up until I brought it home had managed to get in via the poorly fitted connector & created an extensive community. It was placed in boiling water, then popped in the ultrasonic cleaning bath. Having buzzed it, it was placed in the bottom oven, whilst a cake cooked in the top.
I’m unaware of any temperature or gas Mk numbers but it was bone dry when it came out.
Replied by Notanumber on topic fuzzy fuses...
Posted 1 year 8 months ago #209242
I agree with what you said about Lucas electrics being unfairly blamed. Its nothing new, as far back as the MGB people moaned about Lucas electrics but almost every instance there has turned out to be due to lack of maintenance over the passage of time. That said, it was madness to leave several key circuits such as the fuel pump unprotected by fuses. At least with the F / TF we don't have to worry about that
Time to create page: 0.401 seconds
