Roof rot?
  • Hogweed
Roof rot? was created by Hogweed
Posted 1 year 8 months ago #209534
Over the last couple of years, my roof has been changing colour - looks almost as if somebody has hit it with one of those bombs made of dyed flour
When I first had the car, I tried to keep it sweet with one of those "restore and protect" kits - Autoglym maybe? Didn't make a lot of difference that I could see...
Anybody got any tips for restoration/upkeep?
Thanks
by Hogweed
Replied by Pharg55 on topic Roof rot?
Posted 1 year 8 months ago #209535
I wonder if it was a different colour previously?
There are soft top roof dyes available, some also recommend using their pre-dye solution to help it "take". I've used one of the dyes on mine, and it has made an appreciable difference.
by Pharg55
Replied by Airportable on topic Roof rot?
Posted 1 year 8 months ago #209536
It is a little odd, have it thatched & set a trend!
Replied by Cobber on topic Roof rot?
Posted 1 year 8 months ago #209537
What colour was it? going by the pic it's a bit hard to tell
  • EllisoJo
Replied by EllisoJo on topic Roof rot?
Posted 1 year 8 months ago #209540
I have found that a wet vacuum cleaner and standard carpet-cleaning products work well for initially cleaning dirty hoods. I bought a dirty, secondhand hood and frame, (with a glass screen) to replace my generally better hood which had a cracked plastic screen). Perhaps needless to say, after a heavy dose of carpet-cleaning products, thorough rinsing with clean water in the wet vac, followed by a few days drying then fresh waterproof and dye will be essential.
Posted 1 year 8 months ago #209541
Looking at it again, it might’ve been red, if so that will be the hardest colour to get right, most red pigments are prone to fading and also the most expensive.
it’s quite possible that attempts to restore it to the original deep red will only end up a brownish red….or worse a reddish brown!
If it is meant to be black then it might’ve  Suffered from chemical attack flue to fallout from being parked near some industrial plant.
 I recall when they closed the Goodyear plant in Thomastown,
I had the job of packing up all the machinery ant relocating it to the Somerton plant.
Some well meaning office Johnnie had desided that planting fruit trees all around the perimeter of the grounds was a good idea…the result was fruiT as hard as cricket balls that tasted like rubber. Even the birds and bats wouldn’t though it. The fallout from that plant Goodyear would pay all all the council rates of the neighbours and have their roofs repainted every year.
And I remember down at Yarraville where you had the ICI chemical works, the Pivot fertiliser plant, the CSR.sugar works and the Mobil oil terminal all in a row. The fallout from that lot would strip the paint fr The workers cars before long.
Replied by judiths handyman on topic Roof rot?
Posted 1 year 8 months ago #209542
Once you have cleaned and sorted it, I use one of these,
https://www.mgocspares.co.uk/product/t610/waterproof-half-cover-universal?nodePath=1/3/977/1161/1162/2931
my car sits outside as an older more vulnerable model has the only garage in my possession
It works well, is easy to take on and off and folds into a small square zip up case it comes with.
On very wet days moisture will be captured on the inside of the rear screen, but my TF is my daily driver, so a quick wipe usually sorts it.
Most importantly, the wind has not yet blown it off, the elasticated straps are very good.
The following user(s) said Thank You: Hogweed, TA22GT
Posted 1 year 8 months ago #209563
Its not just the UK where they don't give a toss if they can get away with it then.
I recall local studies on sulphur fall out showing high pollution figures blamed on old petrol vehicles.
When they closed the local steel plant the readings plummeted, just a coincidence apparently.
Personally I would rather the steelworks was still open, maybe fitted with a sulphur scrubber though.
  • Hogweed
Replied by Hogweed on topic Roof rot?
Posted 1 year 5 months ago #210849
Sorry, for some reason the forum doesn't alert me any more when I get a reply! Also when I quote somebody now, I have to reply in the "quote" box - don't know what's going on.
It was a black top!
by Hogweed
  • Hogweed
Posted 1 year 5 months ago #210850
Sorry I missed all the helpful replies - I don't get notifications any more for some reason - must have a look and see if I can figure out why...
So it might have been red at some stage in its life! Oh well. Head gasket went yesterday, so the roof has slipped down the priority list a bit for now
by Hogweed
Replied by talkingcars on topic Roof rot?
Posted 1 year 5 months ago #210874
That roof looks like it needs a deep clean, if it was mine I would start with my jet wash to give it a deep clean blast..
  • Hogweed
Posted 1 year 5 months ago #210875
OK will try that! I think I need something to "re-black" it afterwards though, if anybody has any ideas...
by Hogweed
Time to create page: 0.427 seconds
