Wheel Arch Rust Assessment (Prior to purchase)
- Away
Replied by Airportable on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 1 day ago #209922Those pictures, I would say, would be considered very encouraging & as the chaps say a bit of rubbing back & a paint should be relatively straightforward.
Do you know where to find the paint code?
Replied by Cobber on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 1 day ago #209923"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by TA22GT on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 22 hours ago #209926Your approach on how to do it is spot on.
Only one of the arches looks like you could produce pin holes and if it does repair it from behind by cleaning it up and applying a small patch of glassfibre matting. Don't just put filler over the holes it will come through very quickly. You can underseal the matting.
This weather is not good for painting if you have to do it outside as there is too much moisture in the air and it will blush. Primer won't matter but paint and lacquer will.
Try get it inside and immediately before you spray warm the panel and you will be ok.
Any pics of the whole car?
Replied by EllisoJo on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 21 hours ago #2099271. Whilst that rust could be removed, treated & painted, it looks very much like the surrounding sills and probably other areas have already been re-sprayed. If so, rust has re-appeared and that makes me doubt that the panels were properly prepared before that (cosmetic??) re-spray. If I were considering that car, I would insist on taking a good look underneath, to see what other rust is visible. The front mounts of both the front & rear sub-frames have a reputation for rotting first. There is also a notorious mud-trap at the back of the front wheel arches. Water & muck drop down the wheel-arch liner, and are trapped between plastic & steel. Rot follows.
2. How much service history, invoices or (ideally) a photo history of work being done. Cambelt changes and a properly replaced head gasket are the two "must haves" in my mind, unless the car is cheap.
Back in March 2021, I found rust in the same rear sill area as you. Photos of the rust spots and the re-spray are attached. At least your paint colour will be easier to match than my Starlight Silver!
Replied by Notanumber on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 21 hours ago #209928As others have said do check when the cam belt was last changed and plan to change it f it was much more than 6 years ago.
How much is the seller asking ? What is the rest of the car like ?
- KidCreation
- Apprentice MGer
Replied by KidCreation on topic Wheel Arch Rust Assessment (Prior to purchase)
Posted 4 weeks 16 hours ago #209933As for the rest of the car it's head gasket was done 5000 miles (2 years) ago by Trophy Cars as was the cam belt and water pump, its also had a new clutch, exhaust and stainless steel cooling pipes since then too and i didn't spot any additional rust. the underneath of the sills appeared to be black and felt very solid to the touch, i suspect the black is some sort of rust prevention treatment and it didn't appear to have bubbled (pardon my ignorance but could the black be some kind of treatment coating? and could this also be some of what can be seen where the arch meets the sill in the photo or is that just more rust?)
- KidCreation
- Apprentice MGer
Posted 4 weeks 16 hours ago #209934I think my biggest fear here was me not realising that this is actually very bad and could even be terminal, but if its not then i'm happy to take a go at trying to resolve it, you have to learn somewhere right?
- KidCreation
- Apprentice MGer
Posted 4 weeks 16 hours ago #209935In terms of history and invoices fortunately that's where the car shines! in the last 5000 miles (2 years) its had the cambelt and head gasket done by trophy cars, it's also had stainless steel cooling pipes which i beleive are a key upgrade for protection against this issue as well as new clutch from Rough Luck racing and a new exhaust
- KidCreation
- Apprentice MGer
Posted 4 weeks 15 hours ago #209936The cambelt and head gasket were done 2 years ago with the car having covered 5000 miles since then, and in that time its also had stainless steel cooling pipes, a new exhaust and a new clutch.
The rest of the car seems pretty tidy from what i can tell, i don't have enough TF driving experience to know what's normal and what isn't to be honest and i assume most of the rattles fall into the category of normal, i did find the brake pedal didn't seem to have a huge amount of travel although looking back i'm wondering if i was simply not pressing it hard enough having been spoilt by modern cars and i didn't have any trouble stopping the car either way. definitely needs a new handbrake gaitor but other than that nothing really jumped out as bad.
The car has done just over 53000 miles and is currently up at £5000 though it appears the seller was trying for £6000 originally and from the way the seller was talking about wanting more easy to turn cars (fiestas etc) on his very tiny forecourt i suspect i could get a bit more off it too. It also includes the X-Power hoops and what i'm told is a rare X-Power tonneau cover designed to fit said hoops
Posted 4 weeks 15 hours ago #209937Before I reply to your post on painting the arches I have to comment on the price.
I'm new to MG's but not new to fixing or restoring cars and for £5k that car should be rust free!
Others may agree or disagree with me but it seems way overpriced to me.
I bought a 2002 TF135 this September with 34k miles that is totally rust free both on top and underneath so to me it looks overpriced.
At 5k it should have no rust and a perfect gear lever gaiter.
I'm sure others will make their own observations to help you.
Before you part with cash get a feel for what others think.
- KidCreation
- Apprentice MGer
Posted 4 weeks 15 hours ago #209938Please Log in or Create an account to join the conversation.
Posted 4 weeks 15 hours ago #209939"there was an advisory for front suspension arms corroded (but not weakened) so they'll need doing at some point"
These lower arms are notorious for collecting water & mud and therefore corrode. Either use this as a way to get the price down, or find a better deal!
