Locked driver’s door
Have you tried using the key to unlock the door?
- Uncle Nick
- Apprentice MGer
Yes I’ve tried the key, with the battery connected and disconnected. It doesn’t feel like it’s connected correctly either way.
Can you gain access to the passenger side & remove the card from that, you will be able to see what’s operating by using that as a comparison. Obviously there is no key on that side but the key only recreates the remote signal.
When operating the key, does it feel as if it’s working over its full stroke & is there movement in any of the rods, then use the fob, any movement there?
Compare with the near side.
You really don’t have much room to work but is there any way of gripping the rods you can see & give them a stout thrutch?
In all probability it will be tied up with the “super lock” a hyperbolic name for a facility which is rarely used by anyone & by finding & cutting a wire from the controller, makes sure the problem does not reoccur.
You can buy & quite cheaply an endoscope adapter for your phone/laptop, if you have one you can look at what is happening.
The final solution, as you have already realised is to sacrifice your door card.
I’ll be back in the workshop later & as the drivers door card is off I’ll look at the mech’
I’m Christmas shopping driver this morning, which is why I’m writing this in a Sainsburys car park.
I have found it is often the key not moving the little lever underneath all the way across causing the rod or cable to be stuck in no mans land..neither the fully locked or open position causing everything to jam.
Worth a try.
this is in the unlocked position.
This is in the locked position.
My wife, not being satisfied with one shopping trip, requires further trips to distant continents.
If I accommodate now I can get a full couple of days in the workshop & possibly accrue enough points for her to avert her gimlet eye when a big & heavy parcel arrives.
I was just suggesting the easy options to try 1st.
- Away
Home now & I’ve managed to lock myself out of my car by trying to to see if I could get to any control rods through the gap you have available.
The green rod end clips to the inside handle, or at least it does on mine & it was through jiggling with this did I managed to free up my system (very big sigh of relief).
I’m pretty sure that you have super lock problems, I know of no one who uses it, I don’t know how to engage it & I disconnected it PDQ.
Ideally the S/L control lines should be disconnected from the control box which is behind the centre console & is not easy to access.
You can get to the control wire behind the door cards & it’s the brown/pink wire.
Obviously for you it’s a job to do once over your present hurdle.
I’m sorry I am unable to hand you a silver bullet, however I freed my self inflicted problem off by fudging about, hopefully you might do the same.
I’ll catch up later, if needs be, it’s time for my evening meal.
I think it could just be those rods that are in halfway position so it is in deadlock.
I would be pushing and pulling on those with whatever I could get in there.
Good luck.
- Uncle Nick
- Apprentice MGer
Due to getting caught up with other stuff, I haven’t had the chance to investigate further.
I liberally sprayed Plus Gas over any parts that looked even vaguely like they should move, so hopefully that will have worked some magic.
I’ll report back when I’ve had another chance to try your suggestions. 🤞
