Locked driver’s door
this is in the unlocked position.
This is in the locked position.
My wife, not being satisfied with one shopping trip, requires further trips to distant continents.
If I accommodate now I can get a full couple of days in the workshop & possibly accrue enough points for her to avert her gimlet eye when a big & heavy parcel arrives.
I was just suggesting the easy options to try 1st.
Home now & I’ve managed to lock myself out of my car by trying to to see if I could get to any control rods through the gap you have available.
The green rod end clips to the inside handle, or at least it does on mine & it was through jiggling with this did I managed to free up my system (very big sigh of relief).
I’m pretty sure that you have super lock problems, I know of no one who uses it, I don’t know how to engage it & I disconnected it PDQ.
Ideally the S/L control lines should be disconnected from the control box which is behind the centre console & is not easy to access.
You can get to the control wire behind the door cards & it’s the brown/pink wire.
Obviously for you it’s a job to do once over your present hurdle.
I’m sorry I am unable to hand you a silver bullet, however I freed my self inflicted problem off by fudging about, hopefully you might do the same.
I’ll catch up later, if needs be, it’s time for my evening meal.
I think it could just be those rods that are in halfway position so it is in deadlock.
I would be pushing and pulling on those with whatever I could get in there.
Good luck.
- Uncle Nick
- Apprentice MGer
Due to getting caught up with other stuff, I haven’t had the chance to investigate further.
I liberally sprayed Plus Gas over any parts that looked even vaguely like they should move, so hopefully that will have worked some magic.
I’ll report back when I’ve had another chance to try your suggestions. 🤞
With that thought in mind I note the final paragraph in one write up. It reads in summary as follows, in the event of a serious crash etc the inertia switch will unlock the doors - or words to that effect.
So, perhaps one the more technically electronically minded members might be able to indicate whether it is possible to “fool” the inertia switch by shorting to ground etc to see if that will open the driver’s door?
