Locked driver’s door
Replied by Goodwood on topic Locked driver’s door
Posted 1 year 6 months ago #210250
I have had good experience purchasing second hand parts from the MGF Centre in Wolverhampton (although I was able to source a new door locking mechanism from Rimmer Bros). They might have a supply of RHD door lock mechanisms.
Last Edit:1 year 6 months ago by Goodwood
Last edit: 1 year 6 months ago by Goodwood.
Replied by Airportable on topic Locked driver’s door
Posted 1 year 6 months ago #210251
Corbridge lad on eBay has both LHS & RHS locks, he gets some useful stuff from time to time & although he can’t be classed as cheap, I recon he’s Ok
I’ve met him a few times & found him to a personable individual. The items I have had were good & clean, I don’t live too far away from him, so carriage isn’t a problem, plus if I go the long way round I can have a run up the Ribble valley, returning via the Trough of Bowland.
Replied by TA22GT on topic Locked driver’s door
Posted 1 year 6 months ago #210252
Ahhh...Trough of Bowland...memories of my night rallying days...that and Clapham Station...flat in fifth until you chickened out.
Good to have these contacts.
Replied by Delbourt on topic Locked driver’s door
Posted 1 year 6 months ago #210253
Today I have read up a bit more on this topic and am puzzled as to how the situation is to be overcome if "superlocking" has taken place.
So here is my question
Without access to the door when it is open it is not possible to remove the screws that hold the lock to the door case. Does this mean that once the door card is destroyed to get access to the lock that you have to basically dismantle the lock in-situ such that you can release the interlock that creates the "superlock"?
I ask because as I understand it once "superlock" is activated an interlock is deployed within the lock case that prevents any of the other rod mechanisms from having any effect ~ simply put they are disabled. Or is there something more obvious that I'm overlooking.
Within the case there are three microswitches, 1 to sense if the door is closed/open, 1 to sense if the system is locked or unlocked, and 1 to sense if the key has been used to lock/unlock the door. And the ECU determines whether to power the standard lock or superlock (and which way to operate the motor).
So again if the fob is not having any effect on unlocking the door and superlock has been deployed I cant see any other way of opening the door other than dismantling the lock in situ. Am I wrong? If so please explain.
My only other thought would be to turn ignition on (possibly start the engine) and disconnect the accelerometer that senses that you have run into the big tree. Then see what happens. Or could it be a weak earth? If so where?
Posted 1 year 6 months ago #210254
Great questions.
The "weak earth" at the end caught my attention as so many electrical faults are down to a bad earth in the same way a broken neutral causes so many electrical problems.
After reading the horror stories about "superlock" I might just stop locking my doors.
Posted 1 year 6 months ago #210255
Re reading #210209 the door may not be super-locked. If not there may still be some hope of getting it open.
Posted 1 year 6 months ago #210256
If I were to find myself in this unfortunate position where the door card had to be destroyed to gain access to the lock, any finesse in opening the lock body in the vane hope of resurrecting the faulty/suspect lock mechanism would fall to the appropriate & largest appliance I could get in the space available & lay to waste my adversary.
Even if reparable would you chance a second door card?
Posted 1 year 6 months ago #210257
Don't disagree with that. But lets assume that after wrecking the door card you have access to the lock. If it is superlocked the mechanism prevents any movement of any of the other features as far as I can see.
So, if you cant open the door to access the three retaining screws how do you "do something" that opens the door. The only thing I can think of is to dismantle the lock so that the interlock created by the superlock can be defeated.
Or, what am I missing?
Replied by Cobber on topic Locked driver’s door
Posted 1 year 6 months ago #210260
It make me shake my had in incomprehension that all over the car they cheapscated  and yet they spent money including worthless shit like this and the alarm!
Posted 1 year 6 months ago #210266
Regardless of what we think about the features included in the security system it is a standard feature.
When  applying for insurance cover here in the U.K. we are usually asked a standard series of questions.
Near the top of the list is “what alarm” or other security features are included, soon followed by “what modifications” have been carried out.
So, it is important to have the perishing locks working or declare that one aspect such as “superlock” is disabled. At that point you will be directed to a broker and up goes the cost of insurance.
An insurance company will not care about any self inflicted damage caused to door cards etc whilst trying to overcome a failed superlock.
You might be able to be “economical” with the truth if the car were stolen by answering positively to the question was the car locked. The answer might be “yes” but without declaring no it was not superlocked.
Posted 1 year 6 months ago #210268
I’m unsure just what mechanism is involved in the super lock system. If running the lock motor in reverse disengages the mech, a switching system arranged to disconnect the alarm circuit & engage a momentary reversed polar pulse should resolve the problem.
I’m not advocating this, it is by the way of a thought experiment.
My S/L circuit is disabled by a bullet connector in the door, if I’m required to institute the system that can be connected.
Posted 1 year 6 months ago #210269
It might be best if it is left for each to make their own investigations via Tech bulletins on the associated CDs etc.
My understanding is that the locks each have two motors. One for normal locking, and one for superlock.
Lock/unlock of either motor system is executed by reversing the current through the motor depending on selected action at the time.
As I read what I can find on this topic I get the impression that it is not necessarily the motors that fail but more the associated complexity of the mechanical components in the lock case. The micro switches themselves that detect lock position etc may be a significant contributor to that frailty.
I don’t know this but suspect that if the micro switch does not detect full closure or superlock complete then the motor might continue to run and go through a “loop” . It would be interesting if not helpful to know if anyone else has more experience with this.
Looking at the door handle I removed a while ago I have reminded myself that the associated rod is screwed into the handle mechanism pivot. That suggests some setting up is required.
Time to create page: 0.456 seconds
