Locked driver’s door
Replied by Delbourt on topic Locked driver’s door
Posted 1 week 18 hours ago #210478
Whilst cutting the wire will prevent superlock why is it thought necessary to do that?
My experience relates to the Lucas system but I suspect the details within the lock case are similar if not identical for both Lucas and Pectron systems.
I agree that if the lock on the passenger side ceases to function whilst superlocked then nothing that anyone can do will release the lock.
On the driver's side it is my belief that the key should overcome superlock (but you might need to disconnect the battery first).
If either lock has suffered internal component failure such that broken parts "jam up" a crucial part of the system or prevent a vital movement then it will not matter one bit if it is superlocked or not in my opinion.
Replied by sworkscooper on topic Locked driver’s door
Posted 6 days 21 hours ago #210490
Wire cutters do a fine job.
Hmm, i was thinking more in the way of  removing the offending wire from the plug ( unpinning )
this would allow me to repin it if anything untoward happened.
Replied by Notanumber on topic Locked driver’s door
Posted 6 days 20 hours ago #210492
That's a sensible approach.
Replied by TA22GT on topic Locked driver’s door
Posted 6 days 20 hours ago #210493
Next time I'm in there mine is going to get the snip.
I will fit male female bullet connectors but they will never feel the joy of being joined again.
Life can be cruel.
Time to create page: 0.827 seconds
