Overheating MGF after Engine replacement
  • LeonC
  • Novice MGer
  • Novice MGer
Overheating MGF after Engine replacement was created by LeonC
Posted 1 year 6 months ago #210206
Hi all, I've just joined and was hoping for some help.
I have a 1998 Mg MGF VVC 143bhp , the car has just underwent a decent amount of work.
* New engine
* New water pump
* New thermostat
* New and upgraded radiator and fans
* Bled a series of times from all three bleed points. Jiggle valves also appear to be free. but he was only able to blow test 1.
The car is back up and running, it idles fine but after 15 mins of driving it begins to over heat.
I'm Currently in Northern Ireland and i was wondering if there's any MG mechanics still around as my mechanic cant figure out 'wrong.
I've been told to replace the cover cap on the coolant reservoir incase it is leaking but it appears to be holding the pressure due to the build when it is released. My mechanic has said the coolant is flash boiling when its reaching the engine from the radiator.
Any ideas of who to call or where to go, Im not super mechanically inclined but I'm hopefully getting it back this week and if there any ideas for any things i could check whilst i wait that would be great.
Last Edit:1 year 6 months ago by LeonC
Last edit: 1 year 6 months ago by LeonC.
Replied by Notanumber on topic Overheating MGF after Engine replacement
Posted 1 year 6 months ago #210219
Some of the thermostats for the K series on general sale are known to open at too high a temperature. If you haven't done so already try removing the thermostat or refit the old one after gutting it so it is non restrictive. See if this helps with the overheating
Replied by stubbs_gt on topic Overheating MGF after Engine replacement
Posted 1 year 6 months ago #210222
I have a coreless thermostat you can have if you want, also in Ireland so DM me and i'll post it tomorrow.
Replied by D4KGP on topic Overheating MGF after Engine replacement
Posted 1 year 6 months ago #210226
When I first had my F and worked on it over a period of time I decided to replace the 88 degree stat with a 82 that include a jiggle valve, I believe it might have been the same as fitted to the Metro's not 100% sure now.
It seems to be working ok after a few years now, but the only possible down side of going with a lower temp stat is that the engine may not reach optimum temp for performance. I am now working (very slowly) on my TF 160 VVC which I had thought about going with the PRT system but decided against it for a number of reasons, anyway I fitted the correct 88 degree temp stat in it which also has a jiggle valve, I had to reduce the circumference to make it fit as it was for a Land Rover Discovery. Not tested yet because as I stated, I'm working very slowly on this project. The car was kindly donated to me by Mr Alan Ritchie to whom I am very grateful!
Good luck with sorting the issue. Glyn.
Posted 1 year 6 months ago #210293
Hi so how are things going with this after the advice given by different sources?
Glyn.
Replied by CORKY on topic Overheating MGF after Engine replacement
Posted 1 year 6 months ago #210395
Hi. Very similar problem with my MGF (see Cooling Question). Mine doesn't overheat when Idling, but does overheat if I drive any distance and stop with the engine running - at the lights for example. Has anyone got any experience of using a block tester? I'm thinking of trying to find out if there are any combustion gases in the coolant. They seem to vary in price from a few quid to over one hundred.
Last Edit:1 year 6 months ago by CORKY
Last edit: 1 year 6 months ago by CORKY.
Posted 1 year 6 months ago #210399
Hi stubbs_gt. Please excuse my lack of knowledge, what is a coreless thermostat?
by CORKY
Posted 1 year 6 months ago #210400
It means a normal thermostat that has had the active centre part chopped out out so it is always open and will allow water to flow through
Posted 1 year 6 months ago #210407
Hi don't go with a core less stat because the engine will never reach optimum temp for proper running!
Posted 1 year 6 months ago #210411
Indeed so. It's mostly used either temporarily to prove whether the thermostat was the problem or to be fitted permanently where someone introducing a seperate inline thermostat.
Replied by Airportable on topic Overheating MGF after Engine replacement
Posted 1 year 6 months ago #210413
Just so, I neutered my thermostat when I fitted the PRT.
Posted 1 year 6 months ago #210414
Yep, that's fine. I prepared one when I considered going with a PRT, but decided against it.
Time to create page: 1.119 seconds
