Mystery plug
But in this scenario you should be missing connection on purge control valve. Do you miss it?
The wires being red & black, the historic positive/negative is also odd on an original fitment auxiliary. I think you have a foreigner.
MGR Just bunged up one exhaust until the car got just as far enough away as to reduce the sound pressure level to acceptable amounts, it then opened & the car sped away.
It’s a good thought though.
- BruceTF135
Are you sure that isn't orange/black? Brown is usually much darker.My bad, the wires are actually brown / black which is live with ignition & a black earth. Did Japan spec have anything different, my headlights have rover Japan part stickers but I dont have any history for the car to confirm.
