mg tf 160 bad head gasket
Replied by Cobber on topic mg tf 160 bad head gasket
Posted 2 weeks 1 day ago #210480
Ok that piston is buggered! There is a bit to do to replace it,  it's gonna be a engine out job. the bore is probably damaged too.
Have you rotated the crankshaft whist the head was removed, without anything to secure the bore liners in place? I ask this because the bores can move if not held in place. on these engines when the crank is turned without something to hold the bores in place, this can cause all the bore liners to not seal properly at the bottom and for them to have an  uneven height making the head gasket not seal properly.
this isn't gonna me the cheap fix were hoping for!
Download the workshop manual free from this site.
Where in the world are you? If your in the UK, your cheapest course of action is probably going to be find a good second hand engine.
What's the rest of the car like? I ask because it the whole car may end up  a money pit if it's a rust bucket.
At the very minimum your are up for a S/H piston, new rings, the gasket set, timing belt etc.
You'll probably find that you need to replace the bore liner too, and find that as you go you may need to replace bearings, head bolts, water pump, do some head work, etc.
Price these items before you go much further, I'm not trying to discourage you but if money is tight then you need to assess if it's an economically viable project for you.
I would hate encourage you to waste your time and money on a shitbox that isn't worth it. But if the rest of the car has potential, then maybe it's worthwhile.
You are asking questions in the right place, and we will help walk you through this, but you need to know if it's worth your while.
Last Edit:2 weeks 1 day ago by Cobber
Last edit: 2 weeks 1 day ago by Cobber.
The following user(s) said Thank You: Mexiiiii
Replied by Mexiiiii on topic mg tf 160 bad head gasket
Posted 2 weeks 16 hours ago #210481
Thanks for all the great advice guys! makes working on the car less daunting.
to answer all the questions:
- I'm Located in South Africa (parts aren't super easy to come by but doable, and one can order things from Rimmerbros)
- the car has 136,000 km on it and the body is rust-free and in pretty good nick.
- There is no service history, but I heard the engine running(purchased for about 900 pounds so was willing to risk it) and It couldn't hear any obvious issues and started up easily. There was just an issue where it would stall once it got up to temperature. Quite strange in that it would idle fine, but then I would apply throttle and once it tried idling again it would stall.
- I believe the HG failure was caused by one of the coolant pipes leaking fluid till the car overheated.
- I haven't rotated the crankshaft since removing the head (great tip)
I've already done some work on the cylinder head and am rebuilding it after skimming it and lapping there valves(watching lots of videos to make sure I don't mess up the timing and making sure it's within the head height limit)
 After reading all the messages I'm convinced to go ahead and remove the pistons to asses the damage and at minimum replace the damaged one and all piston rings. Will post my progress/findings here
Last Edit:2 weeks 15 hours ago by Mexiiiii
Last edit: 2 weeks 15 hours ago by Cobber.
Posted 2 weeks 15 hours ago #210482
Seeing as you're not in the UK, then the good 2nd hand engine is probably not an option. Still at least your like me in Australia so won't have the rust horrors that most of our Pomgolian friends have to endure, so although we might have to freight our parts over but at least our cars don't turn into a pile of orange flakes with some glass, plastic and rubber bits sticking out of it, before our amazed gaze!
Replied by TA22GT on topic mg tf 160 bad head gasket
Posted 2 weeks 14 hours ago #210484
Hi Max...your second post gives us so much more information!
Firstly your location and that you have a rust free car. That makes a huge difference and means it's worth doing the engine right.
Secondly your skill level has been elevated due to the work you have already done!
I would take the engine out and strip out the pistons, replace the broken piston and re ring them all. Take out the big end shells and inspect the crankshaft journals. They don't have to be "perfect"..there maybe very fine lines..as long as it's not grooved. The bearing shells will give you a good indication.
If the car is good it makes sense to do it right first time. It keeps the car original and you know you will have a good engine you will look after.
I'm good at building engines, gearboxes etc but I know nothing about these engines specifically..but guess what..there are guys here that do! They can answer very specific questions and will get you thru it.
Good luck!
Replied by David Aiketgate on topic mg tf 160 bad head gasket
Posted 2 weeks 14 hours ago #210486
Welcome to the Tbar.
Something else to consider is where did the pieces of piston material go to? 🤔What additional damage, if any, has been caused?
Replied by Notanumber on topic mg tf 160 bad head gasket
Posted 2 weeks 11 hours ago #210488
I'm not sure what the shipping would be to SA but good used 160 pistons are available with matching cylinder liner for sensible money  https://www.mgfntfbitz.co.uk/shop/160-vvc-piston-k-series-engine/
Last Edit:2 weeks 11 hours ago by Notanumber
Last edit: 2 weeks 11 hours ago by Notanumber.
Posted 5 days 17 hours ago #210668
Finally got around to removing the piston and can properly see the the damage, was actually pretty straight forward  . Struggling a bit to get the liners out so I'm soaking them in penetrating fluid.
It's got the number "135" stamped in the side. Could this be a piston from a 135 engine?(or are they the same and it doesn't matter?
Last Edit:5 days 17 hours ago by Mexiiiii
Last edit: 5 days 17 hours ago by Cobber.
Posted 5 days 17 hours ago #210669
I'm wondering where the bits of broken piston ring have gone ,the missing bit of piston are soft so they might not do much damage before they get blown out through the exhaust  if they were small pieces, but piston rings are hard, and I'd expect to see some damage to the top of the piston and the cylinder head if chunks of piston ring were bouncing about in there.
I wonder if some ham fisted ape hasn't broken the piston installing it,  and pulled the lose bit out before bolting down the head and hoping for the best.
What does the bore of the liner look like?
Posted 5 days 16 hours ago #210670
The big end shell is worn but in a normal way..the crank is probably good but check!
Short pistons..no wonder they like to rev.
I wonder if someone broke a ring whilst replacing them at some time.
Personally I would have left the liners in place unless scoured.
You are far enough on to do a great job of rebuilding it now and the satisfaction you will get is enormous. Well done.
Posted 5 days 15 hours ago #210677
that is quite worrying and I would like to figure out exactly what exactly caused the chip. my one theory is that the liner expanded at that section and the piston started making contact and eventually chipped. But yea, Whoever put this together previously was a bit of an ape and made a lot of little mistakes like using silicone glue to assemble the head and stripping a few threads so not completely unlikely that they broke it. The liner bore looks completely fine at least (will get a picture when I'm tinkering again). I got the suggestion of welding the missing material back on the piston and sanding it to the correct shape. Is this a viable solution?
Posted 5 days 14 hours ago #210678
Thanks!!! haven't removed the liners yet but I did rotate the crank to get access to the piston bolts as I was planning to remove them to clean the water channels a little (They seem to be a little seized and I think the previous owner used some head gasket sealant which is gluing them a little).
Posted 5 days 12 hours ago #210682
Do not even remotely try to weld up that piston!
I will leeave it at that.😉
Time to create page: 0.591 seconds
