Jiggle Valve design feature with the PRT
Jiggle Valve design feature with the PRT was created by Delbourt
Posted 3 weeks 12 hours ago #210487Prior to this the thermostat was located at the cylinder head. With the early system it included two "jiggle valves" (one at the cylinder head and one in the up-&-over hose close to the other end of the cylinder head where one hose join the water rail).
The PRT system retained the jiggle valve in the cylinder head, and we can debate the usefulness of that, but the other appears to be omitted. As the jiggle valve is intended to dispel air but seal against water flow that means that there must be a continuous flow of water to the expansion tank with the PRT arrangement via the 4-way connector.
Is this correct? If not where is the other jiggle valve please?
If no second jiggle valve should there be another restrictor in addition to the one that fits against the water rail to improve the flow to the heater? If so what size and where does it fit?
Replied by D4KGP on topic Jiggle Valve design feature with the PRT
Posted 3 weeks 10 hours ago #210489Please Log in or Create an account to join the conversation.
Replied by Delbourt on topic Jiggle Valve design feature with the PRT
Posted 3 weeks 10 hours ago #210491So my question is basically why do I not need a second jiggle valve?
Did the later TF135's fitted with a PRT have a 2nd jiggle valve? If not why not as they must have experienced water squirting into/across the expansion tank.
Replied by Airportable on topic Jiggle Valve design feature with the PRT
Posted 3 weeks 8 hours ago #210495It was some good while ago, & the memory fades, however I simply bought the collection of pipe work, along with the PRT & neutered the original stat’.
All was well for a time until I realised the PRT wasn’t closing/opening properly; a new one was fitted & after I’d dried out normally service was resumed.
No jiggery pokery with the jiggle valve, nothing was discussed on the subject at the time & so nothing done.
Have I goofed?
Replied by TA22GT on topic Jiggle Valve design feature with the PRT
Posted 3 weeks 8 hours ago #210496Please Log in or Create an account to join the conversation.
Posted 3 weeks 4 hours ago #210499In the earlier system (pre PRT) I suspect the other jiggle valve in the “up and over” hose is to stop it being air locked.
But it would vent any air too but with the ball sealing the vent it would prevent circulation.
So, if it is not fitted in the 4-way system there must be an unrestricted flow to the expansion tank. Exactly how vigorous will no doubt depend on the fluid dynamics.
What I am seeking is someone with a PRT fitted as standard and to find if there is a jiggle valve in that small bore spur from the 4-way T to the expansion tank, and if there isn’t is there a continuous flow when the system has reached full operating temperature.
Anyone help please?
Posted 3 weeks 4 hours ago #210500The jiggle valves in the thermostats I am used to have no ball to seal just a simple twisted piece of rod in the shape of a primitive mushroom!
Good luck!
Replied by Cobber on topic Jiggle Valve design feature with the PRT
Posted 2 weeks 6 days ago #210501Imagine if you had a large bubble of air trapped under a closed thermostat, the wax pellet that opens the thermostat might not be imearsed in the water and then wouldn't know that the water was too hot and not open!
Posted 2 weeks 6 days ago #210502Cobber, thanks for engaging in this. I get what it’s for when it is a small hole in the thermostat.
The floating valve giggle system located at the engine close to the thermostat is intended to pass any entrained air to the expansion tank. The ball then floats in the coolant before sealing with minimal flow (if any) passing through it.
In the pre PRT cars there is another in the “up and over” hose at the other end of the engine. In the PRT cars there is no “up and over” hose it is not required and uses a 4-way “T” piece. In that case water has an unlimited flow path to the expansion tank unless something else is included instead.
If there is something to include what is it please?
Is that restriction needed or is free flow vital .
It would be very helpful if someone with a factory fitted PRT could report if there is a small steady flow across the tank from that small hose to the expansion tank once up to temperature from the 4-way T.
Posted 2 weeks 6 days ago #210504"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 2 weeks 6 days ago #210508I hope you can find a conclusive answer as to the need of one.
- BruceTF135
Replied by BruceTF135 on topic Jiggle Valve design feature with the PRT
Posted 2 weeks 1 day ago #210606I have to confess to knowing almost nothing about the jiggle valves. I assumed my car must have one (or more) but I have no idea where it is or what it looks like! I remember from the thermostat in my Austin A35 that it had a strange little dangly metal bit hanging through a small hole in the metal ring around the stat. I never knew what it was; was that a jiggle valve?
What I can say, with some degree of certainty, is that water pumps into the expansion vessel right from starting the engine. It can be seen quite clearly with the pressure cap removed. I have assumed that this is normal.
Does this help at all? It's chucking it down now, but I am happy to check it out if it answers any questions.
