Jiggle Valve design feature with the PRT
Replied by TA22GT on topic Jiggle Valve design feature with the PRT
Posted 1 week 6 days ago #210607
Yes Bruce.. that metal twirly thingy in your A35 was the..jiggle valve...words that are never, ever spoken anywhere in car forums except concerning MG's.
My 2002 TF is apparently pre PRT and is staying that way. The water system operates perfectly and long may it continue.
Replied by Delbourt on topic Jiggle Valve design feature with the PRT
Posted 1 week 6 days ago #210610
Re #210606
Thank you Bruce, that does help.
In my pre PRT I have not detected such a flow. There are three routes in as far as I can see Two from jiggle valves and one from the water rail local to the stat or more probably the stat itself. Until I get better access I can't confirm that.
I have seen bubbles come up into the expansion tank once before not long after having to top it up (part of the reason why I'm investigating all this is to overcome the potential drips from hose joints).
As the 4-way "T" arrangement does not seem to include a "jiggle valve" whereas the "up and over hose" does I expect to see that flow Bruce describes unless there is another valve "somewhere" that I can't locate/define.
So if anyone else can confirm what Bruce has reported that would be good.
by Delbourt
Time to create page: 0.627 seconds
