HOOD REMOVAL
  • EllisoJo
Replied by EllisoJo on topic HOOD REMOVAL
Posted 1 year 6 months ago #210704
    Digcot65
The clips, or where 4 should be, are now circled in red.
AMIN:
Since the update, whenever I quote someone's message, My new text seems to become part of the quote.  Am I doing something wrong??
The following user(s) said Thank You: digcot65
Replied by Cobber on topic HOOD REMOVAL
Posted 1 year 6 months ago #210706
EllisoJo post=210704 userid=8880
  Digcot65
AMIN:
There is a trick to doing quotes with the new version of the forum software.
You need to first click the quote button then once the new window comes up, you need to start waving your cursor under the post you wish to quote.  If you get this bloody silly procedure right a dotted red line with a red box containing an arrow will appear. click on that little red box then proceed to type your reply to the quote.
It's a bloody stupid, poorly thought out "improvement" by the forum software supplier, not something that I think we can do anything about.
The following user(s) said Thank You: EllisoJo
  • EllisoJo
Posted 1 year 6 months ago #210715
Thanks, Cobber, I will try that procedure next time I want to use Quote, but I suspect I will revert to high - lighting the piece of text I want to quote,then use cut & paste that text into a reply with "so-and-so said "pasted text" followed by my reply.
As ever, your explanation is clear & helpful, with proper illustrations which are invaluable.
Replied by David Aiketgate on topic HOOD REMOVAL
Posted 1 year 6 months ago #210727
Unfortunately, if you use an android tablet(like me) Cobber's method still doesn't work, which pees me off greatly,🤣
Replied by digcot65 on topic HOOD REMOVAL
Posted 1 year 6 months ago #210732
I`ve removed the plastic cover ,to get at the hood bolts .If it wasn`t for the Forum I wouldn`t have had a clue what to do after I`d remover the three screws and the deflector blocks When a member said the plastic cover was tight ,wow tighter than a ducks backside and that`s water tight !!! Are there just the two bolts as in the photo to lift the hood and frame off .If so that`s amazing ,I restored a Triumph Stag some tome ago and had to buy another hood for it .There were three bolts holding each side and when the bolts were finger tight it was a few hours job to get the hood in the correct position  Still talking about tightness I removed the old oil filter this morning  ,after flushing the engine with 5lt flushing oil and I have never in 25+ years of restoring cars had a filter so tight .It took me over an hour to remove it .Even with a chain clamp and two hands pushing the chain lever it was solid .After driving a long screw driver through the filter a couple of times and then a lot of force did it come off .Once the seal had broken it unscrewed as normal .
Replied by D4KGP on topic HOOD REMOVAL
Posted 1 year 6 months ago #210734
Yes just 4 bolts holding the hood frame, you say about oil filter removal I've had the same problem in the past, and as you done I've often reverted to the screwdriver method. Now I've bought a removing tool that clamps like the mole grips, but not used it yet. When you come to refit the top of the T bar facia use some petroleum jelly or silicone grease on the pins, makes it easier to remove again. Keep up the good work. Glyn.
Posted 1 year 6 months ago #210740
Where are the 4 I can see the two of them Len
Replied by Notanumber on topic HOOD REMOVAL
Posted 1 year 6 months ago #210745
Just 2 bolts on each side to hold the hood mechanism. It's advisable to put some bungee straps or similar round the hood to stop it from opening. Assuming the clips at the rear edge of the hood are undone then the whole hood frame can be lifted out of the car when the 2 bolts each side are removed. It may be best to have someone help you to lift, more to avoid any chance of the frame scratching the paintwork than it being a particularly heavy weight.
Posted 1 year 6 months ago #210753
Are the two bolts ,one above the other Len
Posted 1 year 6 months ago #210755
For sure yes.
Posted 1 year 6 months ago #210757
Having worked on a few convertibles it has to be said the F/ TF hood is a thoroughly excellent yet simple design. The way that the hood can be so easily removed is excellent.
I'd allowed a day to swap my hood over but I was done in an hour.  It wasnt a problem that the person helping me lift off and on had no experience working on cars.
Other than the fiddly removal of  the plastic T bar the rest of the hood removal and refitting process doesnt really take much longer than say fitting or removing a hardtop.
Posted 1 year 6 months ago #210769
Hello I`ve undone all of the bolts holding the hood in place and partially folded it to store .I clean it when the weather improves ,when I`ve finished this ,what is the best way to offer it back onto the car .Folded as though the hood is in the over the car ,or folded back Len
Time to create page: 0.416 seconds
